Built-in operators
Javascript offers built-in operators in the following categories:
Assignment operators
These operators are used to assign the value of expressions to variables.
= operator
var variable = expression;
The assignment operator is used to assign the value of an expression to the variable.
It is an error to attempt to assign to a constant.
+= operator
variable += expression;
This operator adds the value of the expression to the variable. It is the same as:
 variable = variable + expression;
but is shorter to write and less error-prone.
See also += string operator.
-= operator
variable -= expression;
This operator subtracts the value of the expression from the variable.
*= operator
variable *= expression;
This operator multiplies the value of the expression by the value of the variable.
/= operator
variable /= expression;
This operator divides the value of the variable by the value of the expression.
%= operator
variable %= expression;
This operator divides the variable by the expression and assigns the remainder of the division (which may be 0), to the variable.
&= operator
variable &= expression;
This operator performs a bit-wise AND on the value of the expression and the value of the variable and assigns the result to the variable.
^= operator
variable ^= expression;
This operator performs a bit-wise OR on the value of the expression and the value of the variable and assigns the result to the variable.
|= operator
variable |= expression;
<<= operator
variable <<= expression;
This operator performs a bit-wise left shift on the variable by an expression number of bits. Zeros are shifted in from the right.
>>= operator
variable >>= expression;
This operator performs a bit-wise (sign-preserving) right shift on the variable by an expression number of bits.
>>>= operator
variable >>>= expression;
This operator performs a bit-wise (zero-padding) right shift on the variable by an expression number of bits.
Arithmetic operators
These operators are used to perform arithmetic computations on their operands.
+ operator
operand1 + operand2
This operator returns the result of adding the two operands (operand1 and operand2).
See also + string operator.
++ operator
++operand; // pre-increment
operand++; // post-increment
The pre-increment version of this operator increments the operand and returns the value of the (now incremented) operand.
The post-incremented version of this operator returns the value of the operand and then increments the operand.
- operator
var result = operand1 - operand2; // subtraction
operand = -operand;               // unary negation
The subtraction version of this operator returns the result of subtracting its second operand (operand2) from its first operand (operand1).
The unary negation version of this operator returns the result of negating (changing the sign) of its operand.
-- operator
--operand; // pre-decrement
operand--; // post-decrement
The pre-decrement version of this operator decrements the operand and returns the value of the (now decremented) operand.
The post-decremented version of this operator returns the value of the operand and then decrements the operand.
* operator
operand1 * operand2
This operator returns the result of multiplying the two operands (operand1 and operand2).
/ operator
operand1 / operand2
This operator returns the result of dividing the first operand (operand1) by the second operand (operand2).
Note that division by zero is not an error. The result of division by zero is Infinity.
% operator
operand1 % operand2
This operator returns the integer remainder (which may be 0) from the division of operand1 by operand2.
String operators
These operators provide string functions using operators. Many other string functions are available, see String.
+ string operator
str1 + str2
This operator returns a string that is the concatenation of its operands, (str1 and str2).
See also + arithmetic operator.
+= string operator
str1 += str2
This operator appends its second operand (str2) onto the end of the first operand (str1).
See also += assignment operator.
Logical operators
These operators are used to evaluate whether their operands are true or false. The binary operators use short-circuit logic, that is, they do not evaluate their second operand if the logical value of the expression can be determined by evaluating the first operand alone.
&& operator
operand1 && operand2
This operator returns an object whose value is true if both its operands are true; otherwise it returns an object whose value is false.
Specifically, if the value of operand1 is false, the operator returns operand1 as its result. If operand1 is true, the operator returns operand2.
|| operator
operand1 || operand2
This operator returns an object whose value is true if either of its operands are true; otherwise it returns an object whose value is false.
Specifically, if the value of operand1 is true, the operator returns operand1 as its result. If operand1 is false, the operator returns operand2.
! operator
! operand
If the operand's value is true, this operator returns false; otherwise it returns true.
Comparison operators
These operators are used to compare objects and their values.
== operator
operand1 == operand2
Returns true if the operands are equal; otherwise returns false.
!= operator
	operand1 != operand2
Returns true if the operands are not equal; otherwise returns false.
=== operator
operand1 === operand2
Returns true if the operands are equal and of the same type; otherwise returns false.
!== operator
operand1 !== operand2
Returns true if the operands are not equal or if the operands are of different types;otherwise returns false.
> operator
operand1 > operand2
Returns true if operand1 is greater than operand2; otherwise returns false.
>= operator
operand1 >= operand2
Returns true if operand1 is greater than or equal to operand2; otherwise returns false.
< operator
operand1 < operand2
Returns true if operand1 is less than operand2; otherwise returns false.
<= operator
operand1 <= operand2
Returns true if operand1 is less than or equal to operand2; otherwise returns false.
Bit-wise operators
& operator
operand1 & operand2
Returns the result of a bit-wise AND on the operands (operand1 and operand2).
^ operator
operand1 ^ operand2
Returns the result of a bit-wise XOR on the operands (operand1 and operand2).
| operator
operand1 | operand2
Returns the result of a bit-wise OR on the operands (operand1 and operand2).
~ operator
~ operand
Returns the bit-wise NOT of the operand.
<< operator
operand1 << operand2
Returns the result of a bit-wise left shift of operand1 by the number of bits specified by operand2. Zeros are shifted in from the right.
>> operator
operand1 >> operand2
Returns the result of a bit-wise (sign propagating) right shift of operand1 by the number of bits specified by operand2.
>>> operator
operand1 >>> operand2
Returns the result of a bit-wise (zero filling) right shift of operand1 by the number of bits specified by operand2. Zeros are shifted in from the left.
Special operators
?: operator
expression ? resultIfTrue : resultIfFalse
This operator evaluates its first operand, the expression. If the expression is true, the value of the second operand (resultIfTrue) is returned; otherwise the value of the third operand (resultIfFalse) is returned.
, operator
expression1, expression2
This operator evaluates its first and second operand (expression1 and expression2) and returns the value of the second operand (expression2).
The comma operator can be subtle and is best reserved only for use in argument lists.
function operator
var variable = function( optArguments ) { Statements }
This operator is used to create anonymous functions. Once assigned, the variable is used like any other function name, example variable (1, 2, 3). Specify the argument names (in optArguments) if named arguments are required. If no optArguments are specified, arguments may still be passed and will be available using the arguments list.
The JavaScript function operator supports closures, for example:
    function make_counter( initialValue )
        var current = initialValue;
        return function( increment ) { current += increment; return current; }
    var counterA = make_counter( 3 );  // Start at 3.
    var counterB = make_counter( 12 ); // Start at 12.
    var x1 = counterA( 2 );  // Adds 2, so x1 == 5
    var x2 = counterB( 2 );  // Adds 2, so x2 == 14
    var x3 = counterA( 7 );  // Adds 7, so x3 == 12
    var x4 = counterB( 30 ); // Adds 30, so x4 ==44
Note that for each call to make_counter(), the anonymous function that is returned has its own copy of current (initialized to the initialValue), which is incremented independently of any other anonymous function's current. It is this capturing of context that makes the function that is returned a closure.
See also function declaration and Function type.
in operator
property in Object
Returns true if the given Object has the given property; otherwise returns false.
instanceof operator
object instanceof type
Returns true if the given object is an instance of the given type, (or of one of its base classes); otherwise returns false.
new operator
var instance = new Type( optArguments );
This function calls the constructor for the given Type, passing it the optional arguments (optArguments) if any and returns an instance of the given Type. The Type may be one of the built-in types, one of the library types, or a user-defined type.
Example:
    var circle = new Circle( x, y );
    var file = new File();
this operator
this.property
The "this" operator may only be used within a function that is defined within a class, that is a member function. Within the scope of the function this is a reference to the particular instance (object) of the class's type.
Example:
    class MinMax {
        var _min;
        var _max;
        function MinMax( min, max ) { this._min = min; this._max = max; }
        function max() { return this._max; }
        function min() { return this._min; }
        function setMax( value ) { this._max = value; }
        function setMin( value ) { this._min = value; }
typeof operator
typeof item
This operator returns a type of the object as a string.
Example:
    var f = new Function("arguments[0]*2"); // "object"
    var str = "text"; // "string"
    var pi = Math.PI; // "number"
Functions and built-in objects have a "typeof" of "function".
