DataMap class
A DataMap object represents a collection of private data associated with a session or certificate stored in a CP2 dataset. Each data map retains a reference to its underlying data structure, so it can be used for both reading and writing. Private data items can be stored in three different ways. Each storage type has associated semantics as described in the following table.
Storage type Storage form Encoding Recommended for
test Plain text string Unicode brief segments of human-readable text
base64 Base64 encoded stream Binary short data streams
ref PDF object data stream (i.e. outside of the XMP packet) Binary longer data streams
Note: The scripting API fully supports the "ref" storage type; it implements the appropriate methods to read and write data from and to PDF objects and registers these methods with the C++ toolkit.
Getters [R]
isEmpty( ) : Boolean
Returns true if the collection is empty, false otherwise. The collection is empty if the underlying property is absent or if no private data items are listed for the property.
getTags( ) : String[]
Returns an unordered list of tags used to identify private data items in this collection. The list is empty if the collection is empty.
hasTag( tag : String ) : Boolean
Returns true if the collection contains a private data item with the specified tag, false otherwise.
isString( tag : String ) : Boolean
Returns true if the collection contains a private data item with the specified tag, and that item has storage type "text". Otherwise the function returns false.
isBinary( tag : String ) : Boolean
Returns true if the collection contains a private data item with the specified tag, and that item has storage type "base64" or "ref". Otherwise the function returns false.
isPDFObject( tag : String ) : Boolean
Returns true if the collection contains a private data item with the specified tag, and that item has storage type "ref". Otherwise the function returns false.
getString( tag : String ) : String
Returns the contents of the private data item with the specified tag as a string, or an empty string if there is no such item or if the item does not have storage type "text".
getBinary( tag : String ) : ByteArray
Returns the contents of the private data item with the specified tag as a byte array, or null if there is no such item or if the item does not have storage type "base64" or "ref". If the private data has storage type "base64" it is decoded to binary form before returning.
Setters [W]
These functions may be invoked only on data maps associated with the active session or with a certificate in the active session. Invoking them on any other data map is a programming error and has unpredictable results.
put( tag : String, contents : String )
Places a private data item of storage type "text" in the collection with the specified tag and contents. If an item with the same tag already existed, it is replaced by this new item.
put( tag : String, contents : ByteArray, asPDFObject : Boolean )
Places a private data item of storage type "base64" or "ref" in the collection with the specified tag and contents. If an item with the same tag already existed, it is replaced by this new item. If asPDFObject is false, the item is of storage type "base64" and the binary data is encoded as Base64 before being stored in the XMP packet. If asPDFObject is true, the item is of storage type "ref" and the binary data is stored as a PDF stream object, using one or more lossless encodings as determined by the implementation.
Note: The intention is to avoid introducing new types of stream encodings to the PDF file which could trigger preflight errors; refer to the implementation of Certified PDF 1 in this respect.
remove( tag : String )
Removes the private data item with the specified tag from the collection. If there is no such item, this function does nothing.
