Process class
Note: If you're using a system with '\' file separators, you'll need to use an extra '\' as an escape character for the command names (if there are any separators).
The Process class is used to start external programs and to communicate with them. It can start programs in one of three modes, as described in the following table:
Mode
Function
Comments
Synchronous
Process.execute()
The calling script blocks until the external program has finished; stdout/stderr are collected in the corresponding properties
Asynchronous
new Process().start()
The calling script continues in parallel with the external program and can communicate with its stdin and stdout/stderr through the corresponding write...() and read...() functions
Detached
Process.startDetached()
The external program is started in a separate process; the calling script continues in parallel with the external program but it can NOT communicate with its stdin and stdout/stderr
Static properties
stdout : String
Contains the data sent to stdout during the last call to Process.execute(). This property is read-only.
stderr : String
Contains the data sent to stderr during the last call to Process.execute(). This property is read-only.
Static functions
execute( command : String, stdin : String ) : int
Executes command synchronously and passes stdin to its standard input if specified. When the program ends its output is accessible through Process.stdout and Process.stderr. command can contain both the program and command line arguments, separated by spaces. The function returns the executed command's return code on exit.
Process.execute("help cd");//executes help command with cd arg
job.log(1, Process.stdout); //help output
execute( command : String[ ], stdin : String ) : int
Same as above, except that command is an Array of strings, where the first item is the name of the program and the following items are command line arguments. This version is useful if you have arguments that contain spaces or other characters that would need to be quoted if you just passed a single string command line, since it takes care of the quoting for you.
var comm = new Array("help", "cd");
Process.execute(comm); //executes help command (with cd arg)
startDetached ( command : String ) : bool
Starts command in a new process and detaches from it. command can contain both the program and command line arguments, separated by spaces. The function returns 1 on success; otherwise returns 0. The detached process will continue to live even if the calling process exits.
var started = Process.startDetached("help");
job.log(1, started); //"1" if command was started
job.log(1, Boolean(started)); //"true" if command was started
Constructors
Process( command : String )
Creates a Process object that will execute command. This does not start the process.
var p = new Process("help cd");
Process( command : String[ ] )
var p = new Process(comm);
Properties
arguments : String[ ]
Contains an Array of strings where the first item is the program to execute and the following items are the command line arguments.
//with p initialized as above
var args = p.arguments;
job.log(1, args[1]); //"cd"
workingDirectory : String
Contains the working directory for the process.
running : Boolean
True if the process is currently running; otherwise false. This property is read-only.
exitStatus : Number
Contains the exitStatus of the program when it has finished. This property is read-only.
Member functions
start( env : String[ ] )
Tries to run a process for the command and arguments that were specified with the argument property or that were specified in the constructor. The command is searched for in the path for executable programs; you can also use an absolute path in the command itself. If env is not specified, the process is started with the same environment as the starting process. If env is specified, then the values in the Array of strings are interpreted as environment settings of the form VARIABLE=VALUE and the process is started with these environment settings. If the program could not be started, an exception is thrown.
launch( stdin : String, env : String[ ] )
Runs the process and writes the data stdin to the process's standard input. If all the data is written to standard input, standard input is closed. The command is searched for in the path for executable programs; you can also use an absolute path in the command itself. If env is unspecified, the process is started with the same environment as the starting process. If env is specified, then the values in the Array of strings are interpreted as environment settings of the form VARIABLE=VALUE and the process is started with these environment settings. If the program could not be started, an exception is thrown.
waitForStarted ( seconds : Number )
Blocks until the process has started or until the specified time (in seconds) has passed. Returns true if the process was started successfully; returns false if the operation timed out or if an error occurred. The default value for the argument is 30 seconds. If the value -1 is used, the method will wait infinitely.
waitForFinished ( seconds : Number )
Blocks until the process has finished or until the specified time (in seconds) has passed. Returns true if the process finished; returns false if the operation timed out or if an error occurred. The default value for the argument is 30 seconds. If the value -1 is used the method will wait infinitely.
Note:
It is required to call waitForStarted() before calling waitForFinished().
Example:
theProcess.start();
if( !theProcess.waitForStarted( 60 ) ) // 1 minute to start
    job.fail( "Failed to start process with the arguments: %1", theProcess.arguments );
    return;
if( !theProcess.waitForFinished( 600 ) ) // 10 minutes to finish
    job.log( 3, "Cannot finish the process: %1", theProcess.arguments );
readStdout() : String
Reads what is currently available on the process's standard output.
readStderr() : String
Reads what is currently available on the process's standard error.
canReadLineStdout() : Boolean
Returns true if a line can be read from the process's standard output.
canReadLineStderr() : Boolean
Returns true if a line can be read from the process's standard error.
readLineStdout() : String
Reads one line of text from the process's standard output if available; otherwise returns an empty string.
readLineStderr() : String
Reads one line of text from the standard error stream of this process if available; otherwise returns an empty string.
writeToStdin( buffer : String )
Writes the data buffer to the standard input stream of this process. The process may or may not read this data.
closeStdin()
Closes the standard input stream of the process.
tryTerminate()
Asks the process to terminate. Processes can ignore this if they wish. If you want to be certain that the process really terminates, you can use kill() instead.
kill()
Terminates the process. This is not a safe way to end a process since the process will not be able to do any cleanup. tryTerminate() is safer, but processes can ignore tryTerminate().
