SwitchScripter Fixture pane
The information setup through the Fixture pane defines a simulated run-time environment for script testing purposes, including:
The fixture information is stored in a fixture package alongside the script package (with the same filename but a different extension). The fixture is not part of the definition of a script and may be removed after the script has been tested.
Basic fixture settings
The following table describes the properties displayed in the Properties pane when you select the main item in the Fixture pane (that is, "SwitchScript0" in the example above).
The values of these settings (except for the test folder path) can be accessed in the script at run-time through functions of the Switch class in the Switch scripting API.
Property
Test folder
The absolute path of the folder in which to place files or folders provided to or generated by the script during testing
Global data
The set of global data presented to the script for all scopes
Flow name
The name of the flow to which the script is considered to be attached
Element name
The name of the flow element to which the script is considered to be attached
Injected flow element properties
Additional flow element properties as specified in the Declaration pane
Incoming jobs
The "incoming jobs" section of the fixture defines the jobs that are presented to the script as inputs during testing, including job ticket and metadata info, and the connection on which each job is to be presented.
Use the small tool buttons at the top of the Fixture pane to add, remove and reorder job definitions. In the example above, there are two job definitions ("creaX-cmyk....pdf" and "creaX-spot....pdf").
The following table describes the properties displayed in the Properties pane when you select one of the job definitions in the Fixture pane.
The values of these settings (except for the test file or folder path) can be accessed in the script at run-time through functions of the Job class in the Switch scripting API.
Property
File or folder
The absolute path to the file or folder for this input job
Enabled
Defines whether this input job is indeed included in the simulated test environment (can be used to temporarily exclude a job)
Connection name
The name of the incoming connection on which this job is to be presented
Hierarchy info
The hierarchy path to be stored in the internal job ticket (each segment as a separate string, ordered from top to bottom)
Email addresses
A list of email addresses to be stored in the internal job ticket
Email body text
Email body text to be stored in the internal job ticket
Job state
The job state to be stored in the internal job ticket
Private data
A list of tag/value pairs of private script data to be stored in the internal job ticket
Metadata datasets
A list of metadata dataset references to be stored in the internal job ticket
Outgoing connections
The "outgoing connections" section of the fixture defines the outgoing connections, if any, that are presented to the script, including the values of relevant connection properties.
Use the small tool buttons at the top of the Fixture pane to add, remove and reorder connection definitions. In the example above, there are two outgoing connection definitions ("Accepted" and "Rejected").
The following table describes the properties displayed in the Properties pane when you select one of the connection definitions in the Fixture pane.
Property
Connection name
The name of the outgoing connection
Enabled
Defines whether this outgoing connection is indeed included in the simulated test environment (can be used to temporarily exclude a connection)
Hold files
If set to "Yes", the connection is on hold
Include these jobs
Exclude these jobs
For filter connections, determines which files flow along this connection
Include these folders
Exclude these folders
For folder filter connections, determines which folders flow along this connection
Carry this type of files
For traffic-light connections, determines whether this connection carries data files or log files
Success out
Warning out
Error out
For traffic-light connections, determines whether a file moves along the connection depending on its success status
Injected connection properties
Additional outgoing connection properties as specified in the Declaration pane
