SwitchScripter Toolbar
The toolbar offers a number of tool buttons for frequently used operations (all of which can be accessed via menu items as well).
File
Tool
Create new
Create a new empty script package
Open
Open an existing script package
Save
Save the script package being edited.
View
Tool
Declaration/Fixture pane
Show the Declaration pane or the Fixture pane; toggle between these panes
Properties pane
Show or hide the Properties pane
Messages pane
Show or hide the Messages pane
Edit
Tool
Undo
Undo the most recent text editing operation in the Program pane (supports multipleundo)
Redo
Redo the most recently undone text editing operation in the Program pane
Copy
Copy the selected text in the Program pane to the clipboard
Paste
Paste the clipboard's text contents in the Program pane
Delete
Delete the selected text from the Program pane
Test
Tool
Select entry point
Select the entry point that will be invoked when the "Invoke entry point" button is pressed
The drop-down menu offers a list of all entry points supported by the Switch scripting API; entry points that are not present in the currently visible script program (Program pane) are preceded by a red "unavailable" icon
The menu item "script expression" is special in the sense that it indicates the main script body rather than a specific entry point; it is used for testing script expressions
Invoke entry point
Invoke the selected entry point in the currently visible script program (Program pane), in the context of the text fixture; progress is logged in the Messages pane
This button is enabled only if the selected entry point is present in the currently visible script program, if the Fixture pane is visible, and (for evaluating script expressions and for entry points that take a job argument) if a job is selected in the Fixture pane
Abort
Abort script execution
