Validating property values
Introduction
The "Validation" property of a property definition specifies the mechanism for validating the values of this property.
In most cases, properties are validated while the flow is being designed or just before it is activated. If there are any invalid properties, Switch refuses to activate the flow. For performance reasons, Switch does assume that the result of design-time validation remains valid for the duration of flow activation. While this assumption is correct in most production environments, it is not strictly true for all data types; for example a file path becomes invalid when the target file is removed.
Properties that contain a variable or a script expression are validated while the flow is running, since their value cannot be determined at design time. Just before each invocation of the jobArrived entry point, Switch performs run-time validation for all properties of the flow element that contain a variable or a script expression. If a property value is invalid, Switch fails the job with an appropriate error message.
Note that there is NO run-time validation before calling the timerFired entry point (or any of the other entry points). Using non-static property values from those entry points is risky anyway since there is no job context (and referencing job context from a script expression or variable in those circumstances has undefined results).
Validation at design time
Validation of a particular property value is performed at design time if isPropertyValueStatic() returns true for that property.
The following table describes the standard design-time validation for values entered by a particular property editor. Note that all property values are of data type string or string list.
Property editor
Design-time validation requires that the value…
Single-line text
Is non-empty
Password
Is non-empty
Number
Is non-empty and contains only decimal digits
Hours and minutes
Is non-empty and has the format "hh:mm" (including the colon) where h and m stand for a decimal digit, hh and mm include leading zero if needed, hh is in range 00..23 and mm is in range 00..59
No-yes list
Is one of the strings "No" or "Yes" (exact spelling and case)
Dropdown list
Is one of the custom strings provided for the dropdown list
Literal
Is the fixed string value selected from a predefined list
Choose file
Represents a valid absolute path and that a file exists at the path
Choose folder
Represents a valid absolute path and that a folder exists at the path
Regular expression
Is non-empty and has valid regular expression syntax
File type
Is non-empty and has valid filename pattern syntax
Select from library
Is one of the strings returned by the getLibraryForProperty entry point in the script
Multi-line text
Is non-empty
Script expression
N/A
Single-line text with variables
N/A (if the value contains no variables: Is non-empty)
Multi-line text with variables
Condition with variables
N/A
File patterns
Has at least one item and each item has valid filename pattern syntax
Folder patterns
File types
String list
Has at least one item and each item is non-empty
Select many from library
Has at least one item and each item is one of the strings returned by the getLibraryForProperty entry point in the script
External editor
Validation at run time
Validation of a particular property value is performed at run time if isPropertyValueStatic() returns false for that property.
In this case the property editor used to enter the source value (example: the script expression or text with variables) is no indication for the appropriate validation scheme. Therefore, as a general principle, standard run-time validation allows the computed property value to conform to the validation scheme of ANY of the property's property editors.
Specifically, the validation algorithm works as follows:
Property editor
Run-time validation scheme
Single-line text
Password
Number
Same as design-time scheme
Hours and minutes
No-yes list
Same as design-time scheme, or a Boolean value (*)
Dropdown list
Literal
Choose file
Choose folder
Regular expression
File type
Select from library
Multi-line text
Script expression
File patterns
Same as design-time scheme (for one item), or a Boolean value (*)
Folder patterns
File types
String list
External editor
(*) a Boolean value is represented by one of the strings "true" or "false"
Validation example
Consider a property that specifies a property set which can be provided as a file or it can be part of an external library. The property is set to standard validation and it has the following property editors:
For the first two editors, validation is always performed at design time. For the last two editors, validation is performed at run time (except if the single-line text does not contain any variables). In all cases, the property value is guaranteed to contain one of the following:
For most use cases it can be assumed that these values are mutually exclusive, and that the script code can tell the data types apart from looking at the value. If needed however, the script code can check which editor has been used to enter the value.
