Text encoding
JavaScript strings in Switch store Unicode text in UTF-16 encoding. A database implementation may use a different text encoding, in which case the appropriate conversion must be performed when exchanging text. The ODBC interface unfortunately does not offer a mechanism to discover the text encoding used by the database, so this information must be provided by the user.
Most modern databases use Unicode-aware encodings such as UTF-16 or UTF-8. Older database implementations may use local 8-bit encodings that are not Unicode-aware. To complicate matters even more, some databases use a mixture of encodings (for example UTF-8 for storing text in data fields and UTF-16 for interpreting queries).
Codec Arguments
Selected functions in the Switch database module offer extra "codec" arguments to support databases that use text encodings other than UTF-16.
The DataSource.connect() function allows specifying two codec arguments:
The codecs established with the connect() function are used for all Statement instances derived from the DataSource during the connection. However the Statement.getString() function allows overriding the data-codec on an individual field basis.
Text items exchanged with the database
Function
Text item
Direction
Encoding
connect()
user name and password
To database
query-codec
execute()
SQL statement
To database
query-codec
tables()
Table names
From database
query-codec
columns()
Table name
To database
query-codec
Column names
From database
query-codec
getColumnName() getColumnDataType() getColumnSize()
Column name
From database
query-codec
getNumber() getDate() getString() getBinary()
Column name
From database
query-codec
getString() for STRING and BINARY data types
Data field
From database
data-codec
Default behaviour
The default query-codec and data-codec is UTF-16.
If the data-codec for the connection is UTF-16, the default codec for converting BINARY column data is latin-1 (copy the low byte and clear the high byte of each code point).
If the data-codec for the connection is an 8-bit encoding (i.e. not UTF-16), that encoding is also the default for converting BINARY column data.
The default behavior is summarized in the following table.
Item
Algorithm to determine codec
query-codec
If DataSource.connect() explicitly specifies a query-codec, use that codec. Otherwise use UTF-16
data-codec for STRING data in Statement.getString()
If Statement.getString() explicitly specifies a data-codec, use that code. If DataSource.connect() explicitly specifies a data-codec, use that codec. Otherwise use UTF-16
data-codec for BINARY data in Statement.getString()
If Statement.getString() explicitly specifies a data-codec, use that codec (even if the specified codec is UTF-16). If DataSource.connect() explicitly specifies a data-codec other than UTF-16, use that codec. Otherwise use latin-1
