Environment class
The single instance of the Environment class is passed as an argument to the script entry points that operate out of the context of a particular flow element. By convention, the name for the Environment object is "e" (although the script developer can choose to use another name).
Since the Switch class inherits from the Environment class, any of the functions described in this topic can be called for the Switch class as well. In other words, you can call the Environment class functions with "e.function()" or "s.function()" depending on the argument passed to the entry point.
Logging
log( type : Number, message : String, extra : String or Number )
Logs a message of the specified type (see below) outside of a job context. Where possible use the job.log() function instead, because it includes information about the job in the message.
Log messages are displayed in the Messages pane and in the Progress pane; see also viewing log messages and viewing processes.
Log Type
The "type" argument must have one of the following numeric values:
Numeric type
Display type
1
Info
An informational message that has no other purpose than to inform the user of a certain occurrence
2
Warning
A warning message that informs the user of a recoverable problem or non-fatal error
3
Error
An error message that informs the user of a fatal error
4
Start
A formal message that marks the start of a task that should be displayed in the progress pane
5
Progress
A formal message that marks the completion of a particular portion of a task for which a start message was previously issued
6
End
A formal message that marks the completion of a task for which a start message was previously issued
-1
Debug
An informational message solely intended for debugging purposes
-2
Assert
A message solely intended for debugging purposes that is issued only when a coding error is discovered
Log Message
The message argument and the optional extra argument specify the message being issued, as a constant and variable part. For example:
e.log(2, "Trial period will expire in %1 days", days);
The message argument should be a constant string (that is, not constructed programmatically) because it is used as a key in the localization database. The "extra" argument, when present, replaces the placeholder "%1" in the localized version of the message. If the "extra" argument is missing or null, no replacement takes place.
job.log(1, "sample: %1", ""); //"sample: %1"
Note: Placeholder %1 is always replaced with the value provided in the "extra" argument; if the "extra" argument is missing, the empty value is used. If for any reason you would like to preserve the %1 placeholder in the log message, you can use the following command:
job.log(1, "sample: %1", "%1");
If the extra argument is a number, it is rounded to the nearest integer and then converted to the corresponding decimal string representation. This allows picking alternative messages from the localization database depending on the number (example: "1 day" versus "2 days").
job.log(1, "sample: %1", 3.5); //"sample: 4"
If the extra argument is a string, all leading and trailing white space is removed, and any remaining line breaks (CR, LF, or CRLF) are replaced by a semicolon. This allows passing multi-line text (such as the complete contents of stderr or stdout) to the extra argument without inadvertently causing line breaks in log messages.
var str = "      this \n is \n some \n text      ";
job.log(1, "sample: %1", str); //"sample: this ;  is ;  some ;  text"
Log: Multiple variable parts
The message argument can use the special placeholders "%11", "%12" through "%19" to access the corresponding segment (indexed 1 through 9) of the extra argument interpreted as a list of comma-separated values. If the specified segment does not exist the empty string is used. There is no support for quoted strings so individual values in the list can not contain commas.
job.log(1, "sample: %11 and %12", "one,two"); //"sample: one and two"
Note: Placeholders %2 to %10 are reserved for Switch. Do not use them in scripts.
Log: Showing progress
The messages of type "start", "progress" and "end" cause a task to be displayed in the Progress pane. The extra argument (which must be an integer) is used to indicate the total progress range and the current progress. For example, to indicate a taskconsisting of twelve more or less equal parts one might write:
e.log(4, "Task started", 12);
for (var i=0; i < 12; i++)
     e.log(5, "Task in progress", i);
e.log(6, "Task ended");
Where possible use the job.log() function instead, because it includes information about the job in the Progress pane.
Maintaining global data
The data accessed by these functions is stored in memory as part of the persistent state of the flow execution engine. Access to this data is serialized (to avoid conflicts caused by access in multiple threads) and the content persists across invocations of the flow engine.
It is the script programmer's responsibility to maintain distinct namespaces for their scripts (including those written by other programmers), and to determine the extent to which the data is global. This can be accomplished by providing an appropriate value for the scope argument in the access functions.
setGlobalData( scope : String, tag : String, value : String, persistent : Boolean )
Sets the value of the global data with the specified scope and tag. The parameter "persistent" indicates whether global data value should be preserved between Switch restarts. When set to false, the value will be lost whenever Switch is restarted. By default this parameter is set to true.
getGlobalData(scope : String, tag : String ) : String
Returns the value of a global data variable with the specified scope and tag, or returns an empty string if no global data variable with that scope and tag was set.
lockGlobalData( scope : String)
Acquires a global data lock on the specified scope so that multiple related get/set operations can be performed in the scope without interference from other scripts running in concurrent threads. (It is not necessary to lock global data for a single set or get operation or for multiple unrelated set and get operations).
This function blocks until the requested lock can be obtained.
A script can acquire only a single lock at a time, that is, nested locks are not allowed. While a lock is in effect, the script is allowed to access global data only in the scope on which a lock was acquired. Acquiring a nested lock (even on the same scope) or accessing data outside of the locked scope has undefined (and almost certainly undesirable) results.
unlockGlobalData( )
Releases the current global data lock, if any. Does nothing if there is no current lock.
Switch automatically releases the current lock, if any, after a script returns from the entry point. This is only a safeguard: a script should explicitly release a lock as soon as it is no longer needed.
The following table lists some examples for the value of the scope argument. The table assumes that the variable myOrg contains a URI (unique resource identifier) that uniquely identifies the programmer's organization, and that 's' is a variable which represents a Switch object.
Value of scope argument
The data can be accessed by
myOrg + s.getScriptName()
All copies of this script (even if used in different script elements in the same flow or in different flows)
s.getFlowName() + s.getElementName()
The copy of this script for this script element (if the same script is used twice, there is a separate copy of the data for each script element)
//setting and getting GlobalData
function jobArrived( s : Switch, job : Job ) {
    var scrname = s.getScriptName();
    //get a lock on the specified scope
    s.lockGlobalData("Enfocus" + scrname);
    //set a value
    s.setGlobalData("Enfocus" + scrname, "org", "Enfocus");
    //because of the lock, the value won't be changed
    s.log(1, s.getGlobalData("Enfocus" + scrname, "org"))//"Enfocus"
    //release lock
    s.unlockGlobalData();
Copying files
copy( source-path : String, destination-path : String) : Boolean
Copies the file or folder (including its contents, recursively) specified by the source path to the destination path. Both paths are absolute and include a filename; that is, the destination path specifies the filename of the copied file or folder, not the parent folder in which it should be placed.
Files are copied with full support for platform-specific information such as Mac file types and resource forks (including emulations on Windows), as if copied by a regular flow operation under the control of Switch.
This function returns true if the file or folder is copied successfully; false otherwise.
Note: This function should be used only to copy files to a temporary location; use the Job.sendTo() functions for moving files to outgoing connections.
//example
//copy the jobfile to a temp location
var path =  job.createPathWithName("copy." + job.getExtension());
s.copy(job.getPath(), path);
//send to outgoing connection
job.sendToSingle(path);//only works for single outgoing connection
Moving files
move( source-path : String, destination-path : String, safeMove) : Boolean
Moves the file or folder (including its contents, recursively) specified by the source path to the destination path. Both paths are absolute and include a filename; that is, the destination path specifies the filename of the moved file or folder, not the parent folder in which it should be placed.
If safeMove is true, it will first copy the file or folder to a temporary location before deleting it from the original location. By default this parameter is set to true.
Files are moved with full support for platform-specific information such as Mac file types and resource forks (including emulations on Windows), as if moved by a regular flow operation under the control of Switch.
This function returns true if the file or folder is moved successfully; false otherwise.
Note:
  • This function is relevant only if the source and destination folders are on different volumes (drives/partitions).
  • This function should be used only to move files to a temporary location; use the Job.sendTo() functions for moving files to outgoing connections.
Getting special property values
The following functions allow retrieving the value of the special properties "ApplicationPath" and "ApplicationLicense" without requiring access to a Switch class instance. This is necessary in a scripted plug-in to access these properties from with the getApplicationLicensing entry point. See creating a scripted plug-in for more information on these special properties.
getApplicationPath( ) : String
Returns the centrally managed absolute path to the third-party application associated with this scripted plug-in or null if no such path is available (yet).
getApplicationLicense( ) : String
Returns the centrally managed license key for the third-party application associated with this scripted plug-in or null if no such license key is available (yet).
Getting global user preferences
getServerName( ) : String
Returns the name of the Switch server hosting this execution, as specified by the user in the communication preferences.
getLanguage( ) : String
Returns the name of the currently active language preference, in English. For example, the currently implemented languages are "English" and "German".
getLanguageEnvironment( ) : String
Returns the name of the currently active language environment preference, in English. For example, the currently implemented language environments are "Western" and "Japanese".
getLicenseSerial( ) : Number
Returns the serial number (max. 9 digits) associated with the license entered in the Switch licensing dialog. If multiple licenses are activated, the license with the longest license time period is used. This is always a positive integer, or zero if Switch has not been properly licensed.
isInTrialMode( ) : Boolean
Returns true if Switch currently runs in trial mode; false otherwise.
isLicenseFeatureEnabled( feature : String, version : Number ) : Boolean
Returns true if Switch currently runs in trial mode or if the specified license feature with at least the specified version is currently enabled (because an appropriate license key has been successfully activated through the Switch licensing dialog); false otherwise.
Note: This function is intended solely for internal use by Enfocus or a technology partner employing the Enfocus activation-based license server.
Getting system information
isWindows( ) : Boolean
Returns true if the calling script is running on Microsoft Windows, false otherwise.
isMac( ) : Boolean
Returns true if the calling script is running on Apple Mac OS X, false otherwise.
findRegisteredApplication( key1 : String, key2 : String ) : String
Queries the system for an application that has been registered with one of the specified keys, and returns the absolute path of the application if found or null if not. The function verifies that the returned path is valid (that is, a file exists at the location); if not null is returned instead.
There are two key arguments so that a single call can specify the keys required for two different operating systems. The function automatically figures out which key to use on each operating system. The second key argument can be omitted if it is not needed.
On Windows, the function queries the system registry with the specified key, which must be an absolute registry path. Most professional application installers make a registry entry for this purpose but there is no guarantee.
Mac OS X automatically adds an entry to its application database when an application bundle is installed or copied to the system. Thus on Mac OS X the function queries the system application database with the specified key, which must be the filename of the application bundle (that is, the same name one would use to address the application from AppleScript) or the application's bundle identifier as provided in the property list located inside the application bundle (example: "com.adobe.distiller"). In the latter case, when multiple versions of the application are installed, Mac OS X will choose the most recent version.
findApplicationOnDisk( name1 : String, name2 : String ) : String
Searches the system folder in which applications are usually installed for an application with one of the specified file names and returns the absolute path of the application if found or null if not. There are two name arguments in case the application is named differently on different operating systems. The second name argument can be omitted if it is not needed.
On Windows the function recursively searches the contents of the Program Files folder. If the specified name has no extension, ".exe" is added.
On Mac OS X the function recursively searches the contents of the Applications folder. If the specified name has no extension, the function looks for the specified name AND for the name with ".app" added. The function does not search inside application bundles.
This function may use substantial resources (and time) to complete since it recursively searches the contents of a potentially large folder. Therefore, when called from the findApplicationPath entry point during Switch startup, this function is automatically disabled and immediately returns an empty string without searching.
getSpecialFolderPath( folderID : String ) : String
Returns the absolute path to the special folder indicated by the folderID argument, which must be one of the strings listed in the table below. Returns null if folderID is unknown.
folderID
Returns an absolute path to
ApplicationData
The folder that serves as a common repository for application-specific data for the current user (that is, the user who launched Switch server)
CommonApplicationData
The folder that serves as a common repository for application-specific data that is used by all users
PluginResources
The resource folder associated with the calling script; in the current implementation this is always the folder that contains the calling script package but implementations should not count in this fact
The resource folder is intended for use by scripted plug-ins (see creating a scripted plug-in) and should not be used from regular script packages except for testing; there is no reliable way to transport external resources with regular script packages
SciptData
The folder that serves as a common repository for custom "global" Switch script data; it is shared by all scripts (and all users) so callers must provide unique names for any files stored in this folder
This is a subfolder of the Switch application data root, which has the advantage that its contents is relocated with all other information relevant to the operation of Switch, and can be easily located for diagnostics purposes
getSystemInfo( infoID : String ) : String
Returns the system information indicated by the infoID argument, which must be one of the strings listed in the table below. Returns null if infoID is unknown.
infoID
Returns
UserName
The login name of the current user (i.e. the user who launched Switch server)
supports64bit( ) : Boolean
Returns true if the calling script is running on a 64-bit capable operating system and processor, false otherwise.
Switch always runs in 32-compatibility mode. This function is provided solely to inform a script about operating system capabilities. For example, the script may use the information to select the appropriate version of a third-party application.
The Windows operating system comes in two distinct flavors (32-bit and 64-bit), so this function returns true only if it runs on a 64-bit Windows version.
Mac OS X supports a mix of 32-bit and 64-bit applications when running on a 64-bit capable processor, so this function returns true when running on a 64-bit capable processor. Note that all Intel-based Macs are 64-bit capable.
getServerVersion( ) : number
Returns the version of the Switch server hosting this execution as a decimal number: "major version + update number / 100".
For example, Switch 08 update 6 returns the number 8.06.
This function does not differentiate between pre-release and release builds.
This function was introduced in Switch 08 update 6. If a script may be hosted by an older version of Switch, the script should check for the presence of this function before using it. For example:
if ("getServerVersion" in s && s.getServerVersion() >= 8.07) ...
Supporting time-out
getSecondsLeft( ) : Number
Returns the number of seconds left before the maximum allotted execution time ("abort processes after" in error handling preferences), is reached for this entry point. This allows a script to fail gracefully when it detects that it is getting close to being aborted, or to choose different algorithms based on the allotted time.
Switch provides no guarantees about the actual CPU time that will be available to the script (since many other tasks may be executing in parallel).
Sleeping
sleep ( seconds : Number )
Blocks the calling script for approximately the specified amount of time (in seconds). Other Switch processes are allowed to continue execution in parallel.
Compressing
Note: The "compress" and "uncompress" method are deprecated. We recommend using "archive" and "unarchive", which provide support for Unicode.
compress( source-path : String, destination-path : String, password : String, compress : Boolean ) : Boolean
Places the source file or folder (including its nested contents) into a ZIP archive at the destination path, using the specified password. If the password is null, the archive is not password-protected.
By default (that is, if the compress argument is true, missing or null), the files in the ZIP archive are compressed. If the compress argument is false, the files are stored in the ZIP archive without compression, dramatically reducing processing time. This can be meaningful when speed is more important than size or when the files will not compress well (example: JPEG images).
Returns true if successful, false if not (in which case an appropriate error message is logged).
This function behaves exactly as the compress tool (except that it does not add a unique name prefix to the output archive's name).
compress( source-path : String, destination-path : String, password : String, compress : Boolean, remove_existing_archive: Boolean ) : Boolean
When
is set to true, the zip file existing in the destination folder is removed and a new zip file is created.
If
is set to false, the files are appended to the zip file existing in the destination folder.
For example,
  1. compress("file1.txt", "result.zip", ... , remove_existing_archive="true");
    compress("file2.txt", "result.zip", ... , remove_existing_archive="true");
    As a result, the result.zip file contains only file2.txt.
  2. compress("file1.txt", "result.zip", ... , remove_existing_archive="false");
    compress("file2.txt", "result.zip", ... , remove_existing_archive="false");
    As a result, the result.zip file contains both file1.txt and file2.txt files.
uncompress( source-path : String, destination-path : String, remove-redundant-folders : Boolean, passwords : String[ ] ) : Boolean
Extracts all files from the archive at the source path and places them as a file or folder at the destination path. If the third argument is set to yes, all but the deepest subfolder levels are removed while uncompressing. The last (optional) argument provides a list of passwords for opening password-protected archives.
This function only supports the ZIP archive format.
Note: The first correct password is used for all of the password protected files. If there are files with another password, those files will be skipped.
extract( archive-path : String, file-path : String, destination-path : String, passwords : String[ ] ) : Boolean
Extracts the single file specified by the file-path argument from the source ZIP archive and places it at the destination path in the file system. The last (optional) argument provides a list of passwords for opening password-protected archives.
Note that this function supports only the ZIP archive format; it is intended to extract a manifest from the archive without having to uncompress the complete archive.
Archiving
archive( source-path : String, destination-path : String, password : String, compress : Boolean ) : Boolean
By default (that is, if the archive argument is true, missing or null), the files in the ZIP archive are compressed. If the archive argument is false, the files are stored in the ZIP archive without compression, dramatically reducing processing time. This can be meaningful when speed is more important than size or when the files will not compress well (example: JPEG images).
This function behaves exactly as the compress tool (except that it does not add a unique name prefix to the output archive's name) but adds support for Unicode.
File names (of the files inside the ZIP archive) are UTF-8 encoded.
Very large files (+4 GB) can be archived as well.
archive( source-path : String, destination-path : String, password : String, compress : Boolean, remove_existing_archive: Boolean ) : Boolean
When
If
For example,
  1. archive("file1.txt", "result.zip", ... , remove_existing_archive="true");
    archive("file2.txt", "result.zip", ... , remove_existing_archive="true");
  2. archive("file1.txt", "result.zip", ... , remove_existing_archive="false");
    archive("file2.txt", "result.zip", ... , remove_existing_archive="false");
archive( source-path : String, destination-path : String, password : String, compress : Boolean, remove_existing_archive: Boolean, nameInArchive: String ) : Boolean
By default, the nameInArchive parameter is not specified, but if set, this parameter allows you to rename the contents of the archive.
Example:
archive(/"test.txt","/test.zip", ... , nameInArchive="newName.txt")
The file "test.txt" will be renamed to "newName.txt" before it is archived. The resulting archive will be "test.zip".
unarchive( source-path : String, destination-path : String, passwords : String[ ] ) : Boolean
Extracts all files from the archive at the source path and places them as a file or folder at the destination path. The last (optional) argument provides a list of passwords for opening password-protected archives.
This function supports the ZIP and RAR archive formats.
Very large archives (+4 GB) can be processed as well.
unarchive( source-path : String, destination-path : String, passwords : String[ ], moveResourceForkFiles : Boolean ) : Boolean
If the moveResourceForkFiles parameter is set to true, after unpacking the archive at the destination path, Switch checks if there is a _MACOSX subfolder containing resource fork files. If so, the resource fork files are moved next to the corresponding data fork files and the _MACOSX folder is removed.
If moveResourceForkFiles is set to false, the _MACOSX subfolder (if there is one) is left untouched.
Note: This parameter is only valid on Windows. It's ignored on MAC OSX.
Downloading
download( source-url : String, destination-path : String ) : Boolean
Downloads the file specified by the source URL to the destination path. The source URL must specify the ‘http', 'https', 'ftp' or ‘sftp' protocol, including login and password if applicable. The destination path must include a filename; that is, the it specifies the filename of the copied file, not the parent folder in which it should be placed.
The passive mode is used for ftp protocol. If defined, the FTP proxy preferences are taken into account.
For 'http' and 'https' protocols, the source URL must be URI-encoded.
Returns true if the operation succeeded, false if not. Only one download attempt is made.
Note: This function should be used only to place files in a temporary location; use the Job.sendTo() functions for moving files to outgoing connections.
//example
//download and save enfocus logo
var dpath = job.createPathWithName("logo.png");
var link = "http://www.enfocus.com/~/media/Enfocus"
+ "/Images/Logos/lgo_enfocus.png";
s.download(link, dpath);
job.sendToSingle(dpath); //only works for single outgoing connection
Note: The download method uses server proxy settings for both HTTP and FTP schemes (connections).
Temporary location
createPathWithName( name : String, createFolder : Boolean ) : String
This function has the same semantics as the Job.createPathWithName() function. It is provided as a member of the Environment class so that one can obtain a location for storing temporary files or folders without having access to a job (for example, in the timerFired entry point).
Examples: see other samples above.
Client connection
getClientConnection( ) : ClientConnection
Returns the valid ClientConnection object if the script code is executed in the context of a client connection, otherwise null is returned.
Note: The ClientConnection object is available only in the context of a client connection. If there is a client connection which triggered evaluation of a script, then this script returns a valid ClientConnection object after calling this method. In all other cases, the method getClientConnection returns null. This means that the ClientConnection currently can be used only in JavaScript script expressions specified in Metadata properties of Submit point and Checkpoint flow elements.
See also ClientConnection class.
