The following table describes the main script properties contained in the script declaration, which is part of a script package and is edited using the declaration pane in SwitchScripter.
Name |
The name of this script for identification to a user For scripted plug-ins, a tilde should separate the company name from the tool name (for example, "Adobe~Acrobat Distiller"); Switch will derive appropriate long and short versions from this name. |
Type |
Eement type. Choices are:
Note: The Configurator option is only
available if you have a valid Configurator SDK key activated
on your machine. If selected, a number of additional
properties become available (Sub category in elements pane,
Compatibility, Support Info, Application Discovery
Details)
Include JavaScript |
If set to Yes, the script package includes a JavaScript program and the corresponding tab in the program pane is enabled. This property is dependent on the Type property. |
Include VBScript |
If set to Yes, the script package includes a VBScript program and the corresponding tab in the program pane is enabled. This property is dependent on the Type property. |
Include AppleScript |
If set to Yes, the script package includes an AppleScript program and the corresponding tab in the program pane is enabled. This property is dependent on the Type property and not available if Type=App. |
Keywords |
For scripted plug-ins, defines a list of zero or more keywords, separated by a space, a comma and/or a semicolon. When filtering elements in the Elements pane with the "Search keywords" menu item turned on, this element is displayed if the filter text matches the beginning of at least one of the keywords in this list. |
Tooltip |
For scripted plug-ins, determines the tooltip shown for the icon in the elements pane |
Icon |
The icon to be displayed for a flow element associated with this script package; this must be a PNG image file (not interlaced) with a size of exactly 32x32 pixels in the RGB color space (with support for transparency). |
Password protected |
If set to Yes, the script package is protected by a password; the password is asked when the script package is opened for viewing and editing in SwitchScripter; a script package can always be opened for execution by Switch, even if it is password protected See also password protection |
Password Verify password |
Defines the password for the script package if it is password protected |
Incoming connections |
If set to Yes, the script supports incoming connections |
Require at least one |
If set to Yes, the script requires at least one incoming connection |
Outgoing connections |
Defines to what extent the script supports outgoing connections: "No", "One", or "Unlimited" |
If set to Yes, the script requires at least one outgoing connection (for traffic-light connections: at least one outgoing connection that carries data or data with logs) |
Connection type |
The type of outgoing connections supported by the script, if there are any; choices are:
Include/exclude folder |
For outgoing filter connections, if set to Yes, the standard include/exclude folder properties are automatically injected in the outgoing connections |
Data success Data warning Data error |
For outgoing traffic-light connections, defines which of the standard success, warning and error properties is injected in the outgoing "data" and "data with log" connections |
Log success Log warning Log error |
For outgoing traffic-light connections, defines which of the standard success, warning and error properties is injected in the outgoing "log" connections |
Execution mode |
The execution mode for this script; one of these choices:
Execution group |
The name of the execution group in which instances of this script reside; the precise interpretation depends on the selected execution mode:
Enable performance tuning |
If set to Yes, additional performance tuning is enabled for the script package. When using the script in Switch, an extra property "Idle after job (secs)" will be available, which can be used to fine-tune the flow's performance. If script execution mode is also set to "Concurrent", another property, "Number of slots", will become available. |
Idle after job (secs) |
When performance tuning is enabled, this property contains the default number of seconds the script should remain idle after processing a job. The user can override this value when designing a flow. |
Number of slots |
The number of slots that can be used concurrently by the specific flow element. Possible values are: "0" (unlimited), "Default" (value from Preferences is used) or any number larger than 0. Note that this property can be overridden by the value specified in Preferences > "Concurrent external processes". |
Position in element pane |
For scripted plug-ins, determines the position of the icon in the elements pane; the value of the property has the following format:
Where:
| Obsolete | The list of property tags which were present in the previous versions of the configurator and were removed in the current version. For these tags, Switch does not display the warning messages during flow import or update. See Flow element update for information on entry points available. |
| Obsolete connection | The list of connection property tags which were present in the previous versions of the configurator and were removed in the current version. For these tags, Switch does not display the warning messages during flow import or update. See Flow element update for information on entry points available. |
