The information setup through the Fixture pane defines a simulated run-time environment for script testing purposes, including:
The values of the properties for the flow element to which the script is considered to be attached.
The number of incoming and outgoing connections and the relevant property values for each.
A list of input jobs (files or job folders), and the corresponding job ticket and metadata information for each.
The target location for any output files of the test.
The fixture information is stored in a fixture package alongside the script package (with the same filename but a different extension). The fixture is not part of the definition of a script and may be removed after the script has been tested.
The following table describes the properties displayed in the Properties pane when you select the main item in the Fixture pane (that is, "SwitchScript0" in the example above).
The values of these settings (except for the test folder path) can be accessed in the script at run-time through functions of the Switch class in the Switch scripting API.
Test folder |
The absolute path of the folder in which to place files or folders provided to or generated by the script during testing |
Global data |
The set of global data presented to the script for all scopes |
Flow name |
The name of the flow to which the script is considered to be attached |
Element name |
The name of the flow element to which the script is considered to be attached |
Injected flow element properties |
Additional flow element properties as specified in the Declaration pane |
The "incoming jobs" section of the fixture defines the jobs that are presented to the script as inputs during testing, including job ticket and metadata info, and the connection on which each job is to be presented.
Use the small tool buttons at the top of the Fixture pane to add, remove and reorder job definitions. In the example above, there are two job definitions ("creaX-cmyk....pdf" and "creaX-spot....pdf").
The following table describes the properties displayed in the Properties pane when you select one of the job definitions in the Fixture pane.
The values of these settings (except for the test file or folder path) can be accessed in the script at run-time through functions of the Job class in the Switch scripting API.
File or folder |
The absolute path to the file or folder for this input job |
Enabled |
Defines whether this input job is indeed included in the simulated test environment (can be used to temporarily exclude a job) |
Connection name |
The name of the incoming connection on which this job is to be presented |
Hierarchy info |
The hierarchy path to be stored in the internal job ticket (each segment as a separate string, ordered from top to bottom) |
Email addresses |
A list of email addresses to be stored in the internal job ticket |
Email body text |
Email body text to be stored in the internal job ticket |
Job state |
The job state to be stored in the internal job ticket |
Private data |
A list of tag/value pairs of private script data to be stored in the internal job ticket |
Metadata datasets |
A list of metadata dataset references to be stored in the internal job ticket |
The "outgoing connections" section of the fixture defines the outgoing connections, if any, that are presented to the script, including the values of relevant connection properties.
Use the small tool buttons at the top of the Fixture pane to add, remove and reorder connection definitions. In the example above, there are two outgoing connection definitions ("Accepted" and "Rejected").
The following table describes the properties displayed in the Properties pane when you select one of the connection definitions in the Fixture pane.
Connection name |
The name of the outgoing connection |
Enabled |
Defines whether this outgoing connection is indeed included in the simulated test environment (can be used to temporarily exclude a connection) |
Hold files |
If set to "Yes", the connection is on hold |
Include these jobs Exclude these jobs |
For filter connections, determines which files flow along this connection |
Include these folders Exclude these folders |
For folder filter connections, determines which folders flow along this connection |
Carry this type of files |
For traffic-light connections, determines whether this connection carries data files or log files |
Success out Warning out Error out |
For traffic-light connections, determines whether a file moves along the connection depending on its success status |
Injected connection properties |
Additional outgoing connection properties as specified in the Declaration pane |
