The FileStatistics class allows retrieving certain statistics about file contents for a number of supported file formats. The class does not allow modifying file contents.
Each FileStatistics instance references a particular file, which may be any file on the local file system (whether it is a job or not). The FileStatistics class does not support folders.
Constructs a FileStatistics instance associated with a file specified through its absolute file path. If the specified path references a folder rather than file, the constructed instance behaves as if the referenced file doesn't exist.
The functions in this section work independently of the file's file format.
Returns the absolute file path.
Returns the filename including filename extension if present.
Returns the filename excluding filename extension.
Returns the filename extension after the last '.', or the empty string if there is none.
Returns the Mac file type code as a 4-character string if available, otherwise the empty string.
Returns the Mac creator code as a 4-character string if available, otherwise the empty string.
Returns true if the file matches the specified file type, specified as a filename extension, and false otherwise. A file matches if its filename extension and/or its Mac file type (after conversion) match the specified filename extension.
This function does not examine the file contents.
Returns true if the file exists, false otherwise.
Returns the size in bytes of the file, or zero if the file doesn't exist.
Returns the creation time of the file, or null if the file doesn't exist.
Returns the last modification time of the file, or null if the file doesn't exist.
Returns a read-only embedded metadata dataset object with the XMP data model for the metadata embedded in the file, or null if the file doesn't exist. If the file exists but it has no supported embedded metadata, the function returns a valid but empty dataset.
The backing file path for the dataset points to the file. Metadata may be embedded in the file as an XMP packet and/or as binary EXIF or IPTC tags. Metadata fields from multiple sources are synchronized into a unified XMP data model. See supported file formats for more information.
This function behaves similarly to the Job.getEmbeddedDataset() function; it supports the same file and metadata formats and performs the same synchronizations. The advantage is that it can be used with any file (for example, to iterate over all files inside a job folder). It does not however allow metadata updates (it always returns a read-only dataset) and it does not support folders (i.e. it doesn't look for an appropriate backing file inside a folder).
The functions in this section recognize file format by looking at the file contents. The current implementation supports the following formats:
Filename extension |
AI |
Adobe Illustrator (internal format is PDF) |
AVI |
Video clip |
EPS |
Encapsulated PostScript |
INDD |
Adobe InDesign |
JPEG |
JPEG image |
MOV |
QuickTime movie |
MP3 |
MP3 sound |
Adobe PDF (Portable Document Format) |
PNG |
PNG image |
PS |
Adobe PostScript |
PSD |
Adobe Photoshop |
TIFF |
TIFF image |
WAV |
Wave sound |
Returns the format of the file contents (as one of the strings in the first column of the table above), or the empty string if the format is not recognized or if the file doesn't exist. This function checks for all supported file formats, so it may be a bit slow.
Returns true if the file exists and its contents has the specified format (as one of the strings in the first column of the table above); otherwise it returns false. This function is faster than getFileFormat() since it has to check for only a single file format.
The functions in this section interpret the file contents to obtain certain file-format-specific statistics. The requested statistic is specified through its name (as defined for each format in subsequent sections). Each statistic has a well-defined data type (listed with its description). It is recommended to use the "get" function with the appropriate data type, but reasonable conversions between data types are supported.
The functions return the null object (as opposed to an empty string or a zero number) if:
The file doesn't exist.
The requested statistic is unknown or unsupported for the file format.
The requested statistic is not present in the file or is not applicable to the file.
The result can't be converted to the requested data type.
Returns the requested statistic as a string.
Returns the requested statistic as a list of strings.
Returns the requested statistic as a number.
Returns the requested statistic as a Boolean.
Returns the requested statistic as a date-time.
Statistic data type |
String |
Number |
Boolean |
Date |
String |
Straightforward |
Decimal number representation |
Interpret as in the XMP data model |
Interpret ISO 8601 date-time representation |
Integer |
Decimal representation of the number |
Straightforward |
False if zero; true if nonzero |
Not supported |
Rational |
Decimal floating point representation of the number |
Straightforward |
Not supported |
Boolean |
"true" or "false" |
1 or 0 |
Straight forward |
Not supported |
Date |
ISO 8601 representation of the date-time |
Not supported |
Not supported |
Straight forward |
A string list is converted to another data type by converting the first string in the list (if the list is empty, the conversion is not supported). Any other data type is converted to a string list by converting it to a string and forming a list of one item.
Statistic name |
Data type |
Supported for |
NumberOfPages |
Integer |
All formats |
The number of pages in the document (or a value of one if the format doesn't support multiple pages) |
SamplesPerPixel |
Integer |
JPEG, TIFF, PNG |
Number of components per pixel |
PixelXDimension |
Integer |
JPEG, TIFF, PNG |
Valid image width, in pixels |
PixelYDimension |
Integer |
JPEG, TIFF, PNG |
Valid image height, in pixels |
ColorMode |
Integer |
JPEG, TIFF, PNG |
The color mode used: 0 = Bitmap; 1 = Gray; 2 = Indexed color; 3 = RGB; 4 = CMYK; 7 = Multichannel; 8 = Duotone; 9 = Lab color |
ColorSpace |
Integer |
JPEG, TIFF, PNG |
Color space information: 1 = sRGB; 65535 = uncalibrated |
ICCProfile |
String |
JPEG, TIFF, PNG |
The name of ICC color profile used, if any |
Colorants |
String list |
TIFF |
A list of the names of all colorants for Duotone or Multichannel images; the list is empty for all other color models |
CellWidth |
Integer |
TIFF |
The width of the dithering or halftoning matrix used to create a dithered or halftoned bilevel file |
CellLength |
Integer |
TIFF |
The length of the dithering or halftoning matrix used to create a dithered or halftoned bilevel file |
TileWidth |
Integer |
TIFF |
The width (number of columns) of each tile |
TileLength |
Integer |
TIFF |
The length (number of rows) of each tile |
ColorIntent |
Integer |
PNG |
The sRGB rendering intent: 0 = Perceptual, 1 = RelativeColorimetric, 2 = Saturation, 3 = AbsoluteColorimetric 4 = invalid value |
Version |
String |
The version of the file format (for example "1.6") |
PageWidth |
Rational |
The width of the first page in the document not taking into account page rotation and scaling, in points (derived from the media box) |
PageDefinedWidth |
Rational |
PageEffectiveWidth |
Rational |
The width of the first page in the document taking into account page rotation and scaling, in points (derived from the media box) |
PageHeight |
Rational |
The height of the first page in the document not taking into account page rotation and scaling, in points (derived from the media box) |
PageDefinedHeight |
Rational |
PageEffectiveHeight |
Rational |
The height of the first page in the document taking into account page rotation and scaling, in points (derived from the media box) |
PageLabels |
String list |
A list of the page labels for all pages in the document, or null if none of the pages has a page label |
Colorants |
String list |
A list of the names of all colorants as they appear in Separation and DeviceN color spaces and in page separation info dictionaries in the document |
Fonts |
String list |
A list of the names of all fonts (without subsetting prefix) as they appear in font dictionaries in the document |
SecurityMethod |
String |
The method used to protect the document; possible values: "None", "Password", "Certificate", "LiveCycle" |
The FileStatistics class offers the following additional statistics for the PDF file format:
Statistic name |
Data type |
PageBoxesEqual |
Boolean |
True if all pages have identical page boxes; false otherwise (verifies media, crop, bleed, trim and art box) |
MediaBoxWidth |
Rational |
The width of the media box for the first page in the document not taking into account page rotation and scaling, in points This is a synonym for the ‘PageWidth' statistic |
MediaBoxDefinedWidth |
Rational |
MediaBoxEffectiveWidth |
Rational |
The width of the media box for the first page in the document taking into account page rotation and scaling, in points This is a synonym for the ‘PageWidth' statistic |
MediaBoxHeight |
Rational |
The height of the media box for the first page in the document not taking into account page rotation and scaling, in points This is a synonym for the ‘Pageheight' statistic |
MediaBoxDefinedHeight |
Rational |
MediaBoxEffectiveHeight |
Rational |
The height of the media box for the first page in the document taking into account page rotation and scaling, in points This is a synonym for the ‘Pageheight' statistic |
CropBoxWidth |
Rational |
The width of the crop box for the first page in the document not taking into account page rotation and scaling, in points |
CropBoxDefinedWidth |
Rational |
CropBoxEffectiveWidth |
Rational |
The width of the crop box for the first page in the document taking into account page rotation and scaling, in points |
CropBoxHeight |
Rational |
The height of the crop box for the first page in the document not taking into account page rotation and scaling, in points |
CropBoxDefinedHeight |
Rational |
CropBoxEffectiveHeight |
Rational |
The height of the crop box for the first page in the document taking into account page rotation and scaling, in points |
BleedBoxWidth |
Rational |
The width of the bleed box for the first page in the document not taking into account page rotation and scaling, in points |
BleedBoxDefinedWidth |
Rational |
BleedBoxEffectiveWidth |
Rational |
The width of the bleed box for the first page in the document taking into account page rotation and scaling, in points |
BleedBoxHeight |
Rational |
The height of the bleed box for the first page in the document not taking into account page rotation and scaling, in points |
BleedBoxDefinedHeight |
Rational |
BleedBoxEffectiveHeight |
Rational |
The height of the bleed box for the first page in the document taking into account page rotation and scaling, in points |
TrimBoxWidth |
Rational |
The width of the trim box for the first page in the document not taking into account page rotation and scaling, in points |
TrimBoxDefinedWidth |
Rational |
TrimBoxEffectiveWidth |
Rational |
The width of the trim box for the first page in the document taking into account page rotation and scaling, in points |
TrimBoxHeight |
Rational |
The height of the trim box for the first page in the document not taking into account page rotation and scaling, in points |
TrimBoxDefinedHeight |
Rational |
TrimBoxEffectiveHeight |
Rational |
The height of the trim box for the first page in the document taking into account page rotation and scaling, in points |
ArtBoxWidth |
Rational |
The width of the art box for the first page in the document not taking into account page rotation and scaling, in points |
ArtBoxDefinedWidth |
Rational |
ArtBoxEffectiveWidth |
Rational |
The width of the art box for the first page in the document taking into account page rotation and scaling, in points |
ArtBoxHeight |
Rational |
The height of the art box for the first page in the document not taking into account page rotation and scaling, in points |
ArtBoxDefinedHeight |
Rational |
ArtBoxEffectiveHeight |
Rational |
The height of the art box for the first page in the document taking into account page rotation and scaling, in points |
Statistic name |
Data type |
PDFXVersionKey |
String |
The contents of the PDF/X version key in the document, or the empty string if there is no such key; one of the following values may be returned:
The PDF/X version key indicates a claim that the document conforms to the PDF/X specification, but it does not offer any guarantees |
The FileStatistics class offers the following additional statistics for the PDF file format.
Obtainging the information for these statistics requires parsing the complete page contents, so it might be time consuming.
Statistic name |
Data type |
ColorSpaceFamilies |
String list |
A list of the names of all color space families actually used in the document's page contents; the following names may be returned: DeviceGray, DeviceRGB, DeviceCMYK, CalGray, CalRGB, Lab, ICCBasedGray, ICCBasedRGB, ICCBasedCMYK, Indexed, Pattern, Separation, DeviceN. For Indexed or Pattern, the underlying color space families are also listed |
TransparentColor |
Boolean |
True if the document's page contents uses transparency for defining colors; false otherwise |
FontTypes |
String list |
A list of the names of all font types actually used in the document's page contents; the following names may be returned:
var fileStat = new FileStatistics(job.getPath());
var created = fileStat.getCreated();
s.log(1, "Creation date: " + created);
var numberOfPages = fileStat.getNumber("NumberOfPages");
s.log(1, "Number of pages: " + numberOfPages);
