Main script properties
The following table describes the main script properties contained in the script declaration, which is part of a script package and is edited using the declaration pane in SwitchScripter.
Property
Name
The name of this script for identification to a user
For scripted plug-ins, a tilde should separate the company name from the tool name (for example, "Adobe~Acrobat Distiller"); Switch will derive appropriate long and short versions from this name.
Type
Eement type. Choices are:
  • App
  • Configurator
  • Script (= regular script, for example for use with the Script element in Switch)
Note: The Configurator option is only available if you have a valid Configurator SDK key activated on your machine. If selected, a number of additional properties become available (Sub category in elements pane, Compatibility, Support Info, Application Discovery Details)
Include JavaScript
If set to Yes, the script package includes a JavaScript program and the corresponding tab in the program pane is enabled. This property is dependent on the Type property.
Include VBScript
If set to Yes, the script package includes a VBScript program and the corresponding tab in the program pane is enabled. This property is dependent on the Type property.
Keywords
For scripted plug-ins, defines a list of zero or more keywords, separated by a space, a comma and/or a semicolon. When filtering elements in the Elements pane with the "Search keywords" menu item turned on, this element is displayed if the filter text matches the beginning of at least one of the keywords in this list.
Tooltip
For scripted plug-ins, determines the tooltip shown for the icon in the elements pane
Icon
The icon to be displayed for a flow element associated with this script package; this must be a PNG image file (not interlaced) with a size of exactly 32x32 pixels in the RGB color space (with support for transparency).
Password protected
If set to Yes, the script package is protected by a password; the password is asked when the script package is opened for viewing and editing in SwitchScripter; a script package can always be opened for execution by Switch, even if it is password protected
See also password protection
Password
Verify password
Defines the password for the script package if it is password protected
Incoming connections
If set to Yes, the script supports incoming connections
Require at least one
If set to Yes, the script requires at least one incoming connection
Outgoing connections
Defines to what extent the script supports outgoing connections: "No", "One", or "Unlimited"
If set to Yes, the script requires at least one outgoing connection (for traffic-light connections: at least one outgoing connection that carries data or data with logs)
Connection type
The type of outgoing connections supported by the script, if there are any; choices are:
  • Move
  • Filter
  • Traffic-light
Include/exclude folder
For outgoing filter connections, if set to Yes, the standard include/exclude folder properties are automatically injected in the outgoing connections
Data success
Data warning
Data error
For outgoing traffic-light connections, defines which of the standard success, warning and error properties is injected in the outgoing "data" and "data with log" connections
Log success
Log warning
Log error
For outgoing traffic-light connections, defines which of the standard success, warning and error properties is injected in the outgoing "log" connections
Execution mode
The execution mode for this script; one of these choices:
  • Serialized: entry points for all script instances in the same execution group are never invoked concurrently
  • Concurrent: different instances of the script may be executed concurrently
  • Persistent: entry points are invoked in the same "private" thread (and thus are inherently serialized), and some information can be preserved between invocations
Execution group
The name of the execution group in which instances of this script reside; the precise interpretation depends on the selected execution mode:
  • Serialized: determines the scope of serialization
  • Concurrent: not used
  • Persistent: unambiguously identifies the script implementation
Enable performance tuning
If set to Yes, additional performance tuning is enabled for the script package. When using the script in Switch, an extra property "Idle after job (secs)" will be available, which can be used to fine-tune the flow's performance. If script execution mode is also set to "Concurrent", another property, "Number of slots", will become available.
When performance tuning is enabled, this property contains the default number of seconds the script should remain idle after processing a job. The user can override this value when designing a flow.
Number of slots
The number of slots that can be used concurrently by the specific flow element. Possible values are: "0" (unlimited), "Default" (value from Preferences is used) or any number larger than 0. Note that this property can be overridden by the value specified in Preferences > "Concurrent external processes".
Position in element pane
For scripted plug-ins, determines the position of the icon in the elements pane; the value of the property has the following format:
  • <section>:<sort-key>
Where:
  • <section> is the name of the elements pane section in which the scripted package should appear: Basics, Tools, Communication, Processing, Metadata, or Custom. If it is not one of these, the section defaults to "Custom".
  • <sort-key> is a text string that determines the order in which elements are listed within each section; they are sorted alphabetically on the sort key.
Obsolete The list of property tags which were present in the previous versions of the configurator and were removed in the current version. For these tags, Switch does not display the warning messages during flow import or update. See Flow element update for information on entry points available.
Obsolete connection The list of connection property tags which were present in the previous versions of the configurator and were removed in the current version. For these tags, Switch does not display the warning messages during flow import or update. See Flow element update for information on entry points available.
