The following table describes the properties for each property definition contained in the script declaration which is part of a script package and is edited using the declaration pane in SwitchScripter. A property definition may describe a property injected into the flow element to which the script package will be attached or a property injected into its outgoing connections.
Tag |
The internal name of the property as it will be referred to from the script |
Name |
The name of the property as it will be displayed in the designer's Properties pane |
Tooltip |
A brief description of the property which will be shown in the designer's Properties pane as a tool tip |
Inline editor |
The inline property editor used to edit this property in the designer's Properties pane, if any; see inline property editors for a list of choices and further information |
Editor 1 |
Extra property editors shown for this property in the designer's Properties pane, if any; see other property editors for a list of choices and further information This allows for a maximum of five property editors plus the inline editor. There must be at least one editor (if all editors are set to "None" a single-line text editor is automatically provided). Note that it is meaningless to specify the same editor twice (the second occurrence is ignored), except the external editor; it is possible to use multiple external editors for one script. |
Editor 2 |
Editor 3 |
Editor 4 |
Editor 5 |
Default |
The default value for the property |
Depends on master |
If set to yes, this property is displayed only if its master property has a particular value; the master property is the nearest preceding property with "Depends on master" set to "No" Only a single level of dependency is supported (a dependent property can never be a master) |
Show if master equals |
The string value or values of the master for which this property is displayed; multiple values must be separated by a semicolon |
Validation |
The validation method for the value of this property, which is one of:
See validating property values for further information |
