Regardless of which property editor is used to edit an injected property, the property value is always accessed from the script as a string or a string list (using the getPropertyValue() and getPropertyValueList() functions, respectively). The tables below describe the values for each supported property editor.
The "Inline editor" property of a property definition offers the choices listed in the following table. These property editors are contained inside the property value field in the designer's properties pane. See working with properties for information on using property editors.
Property editor |
Resulting value |
Single-line text |
The text line entered in the inline editor, as a string |
Password |
The hidden value entered in the inline editor, as a string (this is the same as single-line text but the value is hidden) |
Number |
The decimal integer number entered in the inline editor, as a string (this is the same as single-line text but the user can enter only digits) |
Hours and minutes |
A string formatted as "hh:mm" (including the colon) where h and m stand for a decimal digit; hh and mm include a leading zero if needed (this is the same as single-line text but the user can enter only 4 digits) |
No-yes list |
One of the strings "No" or "Yes" |
Dropdown list |
The selected item (that is, one of the provided custom strings); see extra properties below |
The "Editor 1/2/3/4/5" properties of a property definition offers the choices listed in the following table. Most of these property editors are modal dialogs. See working with properties for information on using property editors.
Property editor |
Resulting value |
Literal |
The fixed string value corresponding to the name of the property editor, which must be selected from a predefined list; see extra properties below |
Choose file |
The selected absolute file path, as a string |
Choose folder |
The selected absolute folder path, as a string |
Regular expression |
The regular expression entered in the dialog, as a string |
File type |
The file type selected from a dialog with standard file types, as a string with the corresponding Windows filename pattern(s) |
Select from library |
The string value selected from a list in a "library" dialog; the contents of the dialog is determined by calling the getLibraryForProperty entry point in the script |
Multi-line text |
The text entered in the dialog as a single string that may include newlines |
Script expression |
The result of the script expression evaluated in the context of the job, converted to a string under the JavaScript rules |
Single-line text with variables |
The text line entered in the dialog, as a string, after replacing any variables by their values in the context of the job |
Multi-line text with variables |
The text entered in the dialog box as a single string that may include newlines after replacing any variables by their values in the context of the job |
Condition with variables |
The result of the conditional expression after replacing any variables by their values in the context of the job, as one of the strings "true" or "false" |
File patterns |
The list of pattern strings as they have been entered in the dialog box |
Folder patterns |
File types |
The list of file types selected from a dialog with standard file types, each as a string with the corresponding Windows filename pattern(s) |
String list |
The string values entered in a generic string list dialog; each line is represented is a separate string |
Select many from library |
The string values selected from a list in a "library" dialog; each selected item is represented as a separate string; the contents of the dialog is determined by calling the getLibraryForProperty entry point in the script |
External editor |
The file path to a property set edited by a third-party application; see external property editor |
