The Hypertext Transfer Protocol (HTTP) is an application-level protocol for distributed, collaborative, hypermedia information systems. HTTP functions as a request-response protocol in the client-server computing model. A web browser, for example, may be the client and an application running on a computer hosting a web site may be the server. The client submits an HTTP request message to the server. The server, which provides resources such as HTML files and other content, or performs other functions on behalf of the client, returns a response message to the client. The response contains completion status information about the request and may also contain requested content in its message body. HTTP resources are identified and located on the network by Uniform Resource Locators (URLs) using the http or https URI schemes.
For more information, see http://www.w3.org/Protocols/.
The HTTP class implements a standard HTTP client as defined in RFCs 1945 and 2616. It can be used for communication with an HTTP server and it supports the HTTP as well as the HTTPS protocols.
HTTP communication involves the client sending requests to the server and the server sending a response back. The HTTP class allows using different request methods, defining authentication and defining additional parameters when sending requests, and it allows capturing the response into a file.
The current implementation supports the HTTP request methods PUT, HEAD, GET, POST and DELETE. The methods OPTIONS, TRACE, CONNECT and PATCH are not available, but they are also less important.
The HTTP class supports the HTTP Basic authentication scheme through the user and password properties. Other authentication schemes (Digest, NTLM, Negotiate, Proprietary, OAuth) can be implemented by using the authScheme property.
The addParameter() method can be used to add extra parameters to the request and attaching file is done with the setAttachedFile() method.
The server response is written into a file when the localFilePath property is set. This is whatever the server has responded; it can be the HTML source of the requested URL, JSON or XML data returned by a REST API call, or a file or document that was downloaded. If the server responded with an error, the file will not be created or it will be empty. If this property is not specified, the server response can be obtained as byte array using the getServerResponse() method.
The HTTP class also defines a number of constants that are available in the autocomplete list.
Constructs a new HTTP object. The connection type (HTTP or HTTPS) is automatically detected based on the URL scheme.
var theHTTP = new HTTP();
Contains the URL to be used for request. The URL must be URI-encoded. The method HTTP.encodeURI() can be used to encode the URL.
theHTTP.url = “https://api.dropbox.com/1/fileops/delete”;
The URL must specify the protocol to be used (http:// or https://).
This property specifies if MIME encoding should be used (as specified in RFC1867).
This property will tell the class which type of authorization to perform when the user and password properties are set.
theHTTP.authScheme = HTTP.OauthAuth;
If the authorization property contains a non-empty string, an Authorization HTTP request header is added to the request. This header conveys authorization information to the server. A common use for this property is to specify the OAuth authorization string.
The authScheme property defines the authentication scheme used. In the case of HTTP Basic Authentication (default), the user and password are automatically Base64 encoded by Switch, and the result in the form "Basic [encoded-user-password]" is used for authorization.
theHTTP.authorization = “authorization string”;
If authScheme is set to HTTP Digest Authentication, the user and password properties are used to respond to the HTTP Digest Authentication challenge from the server.
If authScheme is set to NTLM, NTLM authentication will be attempted.
theHTTP.user = “User1”;
This property contains a password if authentication is to be used.
theHTTP.password = “password1”;
The path to a local file that the server response is written to. This can be the file or document being downloaded, JSON or XML data or whatever the server has responded with. If the server responded with an error, the file will not be created or it will be empty.
theHTTP.localFilePath = job.createPathWithExtension( ”pdf”, false );
If the timeOut property is set to "0", all operations will run uninterrupted until successful completion or until an error condition is encountered.
If timeOut is set to a positive value, the class will wait for the operation to complete and if timeOut expires before the operation is complete, the class fails with an error.
The default value for the timeOut property is "60" (seconds).
This property specifies if a proxy server should be used.
If a proxy proxyServer is given, the HTTP request is sent to the proxy instead of the server specified in the url property.
If the proxyServer property is set to a Domain Name, a DNS request is initiated and upon successful termination of the request, the corresponding address is used for sending the HTTP request. If the search is not successful, an error is returned.
This property contains the TCP port for the proxy server (default: 80).
If proxyAuthScheme is set to Basic Authentication, the proxyUser and proxyPassword are Base64 encoded and the proxy authentication token will be generated in the form "Basic [encoded-user-password]".
If proxyAuthScheme is set to Digest Authentication, the proxyUser and proxyPassword properties are used to respond to the Digest Authentication challenge from the server.
If proxyAuthScheme is set to NTLM Authentication, the proxyUser and proxyPassword properties are used to authenticate through NTLM negotiation.
This property contains a password if authentication is to be used for the proxy.
proxyAuthScheme should be set to "NoneAuth" (predefined constant HTTP.NoneAuth) when no authentication is expected.
By default, proxyAuthScheme is "BasicAuth" (HTTP.BasicAuth), and if the proxyUser and proxyPassword properties are set, the component will attempt basic authentication.
If proxyAuthScheme is set to "DigestAuth" (HTTP.DigestAuth), digest authentication will be attempted instead.
If proxyAuthScheme is set to "ProprietaryAuth" (HTTP.ProprietaryAuth), the authorization token will not be generated by the class.
If proxyAuthScheme is set to "NTLMAuth" (HTTP.NTLMAuth), NTLM authentication will be used.
This property contains the HTTP version from the first line of the last server response. The HTTP protocol specifies the structure of this line as: [HTTP version] [Status Code] [Description].
This property is read-only and becomes available after the HTTP request is finished.
This property contains the Status Code from the first line of the last server response. The HTTP protocol specifies the structure of this line as: [HTTP version] [Status Code] [Description]. For the list of HTTP status codes, see http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html.
This property contains the Description from the first line of the last server response. The HTTP protocol specifies the structure of this line as: [HTTP version] [Status Code] [Description].
This property contains the last error string.
Note that when finishedStatus returns “Ok” it does not automatically mean that the request yielded the desired result. The URL provided could have been redirected to another URL. In such a case the HTTP exchange with the server was successful, but nothing happened. It is therefore advisable to also read the properties statusCode and statusDescription to get more details about the completed request. In case of failed status, the lastError property should provide more details about the problem.
if( theHTTP.finishedStatus == HTTP.Failed )
job.fail( ”The request failed: %1”, theHTTP.lastError );
return;
Relevant only for GET request. If set to true, Switch will try to resume the interrupted/broken download if possible. The files containing not finished downloads are stored in the folder defined by the tempFolderPath property.
Relevant only for GET request. This property defines a folder where not finished downloads are stored.
By default this property is empty. In case resumeEnabled is set to true, this property must be set as well. It should contain a folder path pointing to an existing writable folder. Switch does not clean up this folder automatically; it removes the files containing not finished downloads after they are completed by some future request.
Relevant only for HEAD and GET requests. This property determines what happens when the server issues a redirect. If this property is set to false, the HTTP call returns an error if the server responds with an "Object Moved" message (HTTP status codes in the 300 range). If this property is set to true (default), the new URL for the object is retrieved automatically.
This function encodes inURI by replacing each instance of certain characters by one, two, three, or four escape sequences representing the UTF-8 encoding of the character. It assumes that the URI is a complete URI, so it does not encode reserved characters that have special meaning in the URI. It replaces all characters except the following: alphabetic, decimal digits, - _ . ! ~ * ' ( ) ; , / ? : @ & = + $ #
This function decodes inURI by replacing each escape sequence in the encoded URI with the character that it represents.
This function encodes inURIComponent by replacing each instance of certain characters by one, two, three, or four escape sequences representing the UTF-8 encoding of the character.
This function decodes inURIcomponent by replacing each escape sequence in the encoded URI component with the character that it represents.
Sets the path to the file that is appended to the HTTP request, if the HTTP POST or PUT methods are used (through the post() or put() methods). The second argument is optional. It is taken into account only when POST request is sent and MIME encoding is enabled. It specifies the name of the HTTP form data variable that is used by the receiving HTTP server to identify the correct file part of the uploaded MIME package. If this argument is omitted, the default value "file" will be used.
theHTTP.setAttachedFile( job.getPath() );
Warning:
In case of a POST request with MIME encoding enabled, this call identifies the MIME part by adding the following MIME part header:
Content-Disposition: form-data; filename=“name of the file that is being attached”; name=“second parameter”
var tmpFile = job.createPathWithName(job.getName());
if(!s.copy(job.getPath(), tmpFile))
job.fail( "Could not copy the job to the temporary location: %1", tmpFile );
return;
theHTTP.setAttachedFile(tmpFile);
Adds parameters to the HTTP request.
theHTTP.addParameter( ”root”, ”auto” ); theHTTP.addParameter( ”path”, HTTP.encodeURIComponent( job.getName() );
theHTTP.resetParameters();
theHTTP.post();
theHTTP.put();
theHTTP.head();
theHTTP.get();
theHTTP.del();
Returns the progress (in percent) of the current request. This method should be used in combination with the waitForFinished() method.
job.log( 4, "Starting request...", 100 ); // max is 100%
while( !theHTTP.waitForFinished( 1 ) )
job.log( 5, "Executing request", theHTTP.progress() );
job.log( 6, "Finished executing request..." );
var theNames = theHTTP.getHeaderNames();
Returns the byte array containing the HTTP header content. If the header is missing, the empty byte array is returned.
var theValue = theHTTP.getHeaderValue( HTTP.ContentDisposition );
job.log( 1, "Content-Disposition: %1", theValue.toString("ISO 8859-1") );
theValue = theHTTP.getHeaderValue( “Cache-Control” );
job.log( 1, "Cache-Control: %1", theValue.toString("ISO 8859-1") );
theHTTP.addHeader( ”x-metadata”, ”size=12345; path=/” ); theHTTP.addHeader( ”userlogin”, ”OK” );
theHTTP.resetHeaders();
Interrupts the current request to the server.
theHTTP.interrupt();
Appends a body to the HTTP Post and Put requests after the HTTP headers.
var theHTTP = new HTTP( HTTP.NoSSL );
theHTTP.url = "http://httpbin.org/post";
var postBody = new ByteArray("{\"key\":\"value\"}", "UTF-8");
theHTTP.setPostData( postBody,"application/json" );
var theResponseFilePath = job.createPathWithName( job.getNameProper(), false );
theHTTP.localFilePath = theResponseFilePath;
theHTTP.post();
while( !theHTTP.waitForFinished( 3 ) ) { }
job.log( 1, "Request finish status: %1", theHTTP.finishedStatus );
job.sendToSingle(theResponseFilePath) ;
An HTTP cookie (web cookie) is a small piece of data that a server sends to a client. The client may store it and send it back with the next request to the same server.
When receiving an HTTP request, a server can send a 'Set-Cookie' header along with the response. The header value is usually stored by the client, and then sent with requests made to the same server inside a 'Cookie' HTTP header.
The example below shows how a cookie header can be used with an HTTP object:
theHTTP.url = "http://127.0.0.1:51088/auth?username=administrator&password=12345";
theHTTP.post();
while( !theHTTP.waitForFinished( 1 ) ) { }
if( theHTTP.finishedStatus != HTTP.Ok )
job.fail( "Request failed" );
return;
var theCookie = theHTTP.getHeaderValue( HTTP.SetCookie ).toString( "UTF-8" );
if( theCookie.isEmpty() )
job.fail( "Invalid response" );
return;
theHTTP.url = "http://127.0.0.1:51088/api/v1/messages?limit=5";
theHTTP.addHeader( HTTP.Cookie, theCookie );
theHTTP.get();
Note that it is possible to use the predefined constants "HTTP.SetCookie" and "HTTP.Cookie" to denote the names of the required headers.
var theHTTP = new HTTP( HTTP.SSL );
theHTTP.authorization = "authorization string";
theHTTP.url = "https://api-content.dropbox.com/1/files_put/auto/Test.pdf";
theHTTP.post();
job.log( 4, "Upload started", 100);
job.log( 5, "Uploading...", theHTTP.progress() );
job.log( 6, "Upload finished" );
job.log( 1, "Server response: %1", theHTTP.getServerResponse().toString( "UTF-8" ) );
if( theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200 )
job.log( 1, "Upload completed successfully" );
else
job.fail( "Upload failed with the status code %1", theHTTP.statusCode );
return;
job.sendToSingle( job.getPath() );
theHTTP.url = "https://api-content.dropbox.com/1/files/auto/Test.pdf";
theHTTP.localFilePath = job.createPathWithExtension( "pdf", false );
theHTTP.get();
job.log( 4, "Download started", 100 );
job.log( 5, "Downloading...", theHTTP.progress() );
job.log( 6, "Download finished" );
&& File.exists( theHTTP.localFilePath ) )
job.log( 1, "Download completed successfully" );
job.sendToSingle( theHTTP.localFilePath );
else
job.fail( "Download failed with the status code %1", theHTTP.statusCode );
return;
job.sendToNull( job.getPath() );
theHTTP.url = "https://api.dropbox.com/1/fileops/delete";
theHTTP.addParameter( "root", "auto" );
theHTTP.addParameter( "path", "Test.pdf" );
theHTTP.get();
job.log( 1, "Delete in progress" );
job.log( 1, "Delete completed successfully" );
else
{ job.fail( "Delete failed with the status code %1", theHTTP.statusCode );
return;
theHTTP.url = "http://httpbin.org/put";
theHTTP.authScheme = HTTP.NoneAuth;
theHTTP.addHeader( "Content-Type", "application/json" );
theHTTP.put();
job.sendToSingle( theResponseFilePath );
theHTTP.authScheme = HTTP.OauthAuth; theHTTP.authorization = "Bearer " + theAccessToken;
This is the full example of the script code to upload and then delete from Google Drive:
function ErrorExists( inMessage : String ) : bool
var theError = inMessage.find( "error" );
return theError >= 0;
function RefreshToken( job : Job ) : String
theHTTP.addParameter( "refresh_token", "REFRESH_TOKEN" );
theHTTP.addParameter( "client_id", "CLIENT_ID" );
theHTTP.addParameter( "client_secret", "CLIENT_SECRET" );
theHTTP.addParameter( "grant_type", "refresh_token" );
theHTTP.url = "https://accounts.google.com/o/oauth2/token";
theHTTP.post();
job.log( 1, "Refresh token in progress" );
var theFinishedStatus = theHTTP.finishedStatus; // Statuses: Ok, Failed, Interrupted
var theServerResponse = theHTTP.getServerResponse().toString();
if( theFinishedStatus == HTTP.Ok && !ErrorExists( theServerResponse ) )
var theNewTokenWithQuotes = theServerResponse.split( "," )[0].split( ":" )[1];
var theNewToken = theNewTokenWithQuotes.substring( 2, theNewTokenWithQuotes.length - 1 );
job.log( 1, "The new token with quotes: %1", theNewTokenWithQuotes );
job.log( 1, "The new token: %1", theNewToken );
job.log( 1, "Refresh token is successfully" );
return theNewToken;
else if( theFinishedStatus == HTTP.Failed || ErrorExists( theServerResponse ) )
job.log( 1, "Server response: %1", theServerResponse );
job.log( 3, "Refresh token failed with the error: %1", theHTTP.lastError );
else
job.log( 2, "Unknown error" );
var NewAccessToken = RefreshToken( job );
theHTTP.authorization = "Bearer " + NewAccessToken;
theHTTP.url = "https://www.googleapis.com/upload/drive/v2/files";
// send file to Google Drive
theHTTP.post();
job.log( 1, "Upload file to Google Drive in progress" );
job.log( 1, "Upload file to Google Drive completed successfully" );
job.log( 3, "Upload file to Google Drive failed with the error: %1", theHTTP.lastError );
else
// get file ID
var theFileIdWithQuotes = theServerResponse.split( "," )[1].split( ":" )[1];
var theFileId = theFileIdWithQuotes.substring( 2, theFileIdWithQuotes.length - 1 );
theHTTP.url = "https://www.googleapis.com/drive/v2/files/" + theFileId;
// delete file from Google Drive by fileId
theHTTP.del();
job.log( 1, "Delete file from Google Drive in progress" );
job.log( 1, "Delete file from Google Drive is successfully" );
job.log( 3, "Delete file from Google Drive failed with the error: %1", theHTTP.lastError );
else
