Belongs to
Category: Layers
Type: Changes
Since version: 12 update 3
What it does
Allows you to add any selected objects to a specific layer. You can identify the layer
concerned by entering a string (e.g. Layer1). Optionally, you can at the same time remove the
added objects from the other layers.
How to proceed
- Add a "select" Action to the Action List, to select the objects you want to add, for
example Select all.
- Add Add objects to layers to the Action List.
- Enter the name of the layer.
- Optionally, select Remove from other layers.
Example
To add all annotations to a particular layer and remove them from another layer, use the
following
Actions:
Select annotations <!-- Select annotations -->
Add objects to layers <!-- Enter a name, e.g. AnnotationLayer and select Remove from other layers-->
