Check CMap
Belongs to
What it does
Checks if a PDF contains an embedded CMap, and if so, whether its name is consistent with any matching external file. This is necessary for PDF/A compliance.
About CMaps
CMap (Character Map) is a mapping of character codes to an ID. This ID is used to map the characters to the correct glyphs.
CMaps can be external or embedded:
  • When the CMap is external, it is referenced in the PDF by a name.
    Note: Some CMaps are shipped (as external files) along with PitStop.
  • When the CMap is embedded, it's often also referenced inside the PDF.
