Check for garbage after the PDF End-Of-File marker %%EOF
Belongs to
What it does
Checks whether the PDF contains undesired characters after the end-of-file marker EOF.
If this is the case, the PDF is malformed. The last line of a PDF should only contain the EOF marker.
To solve this problem, you can do one of the following:
  • Open the PDF in Adobe Acrobat and save it (using File > Save As ).
  • Process the PDF with PitStop Server (with the option Full Save enabled).
Related Actions
Check for unreadable data in front of the PDF header signature
