Select by graphic state attributes
Belongs to
What it does
Allows you to select objects based on their graphic state attributes.
You can select one of the following object types:
  • Objects with non-PDF/X-1 compliant halftone info
  • Objects with transfer function info
  • Objects with halftone info
  • None
Viewing the graphic state attributes of an object
Proceed as follows:
  1. Select the object, using the PitStop Select Objects tool .
  2. Click to display the Enfocus Inspector.
  3. Select (Prepress) > (General) or (Halftone).
Related Actions
