Select gray
Belongs to
What it does
Allows you to make a selection based on the gray color of the fill and/or stroke color of the objects in the PDF.
You can specify how much the actual gray in the document is allowed to deviate from "true" gray (i.e. gray which doesn't have tones of any other color; for RGB this means that the percentage of Red, Gray and Blue is the same; for CMYK, this holds for Cyan, Magenta and Yellow).
