Select text by key phrase
Belongs to
What it does
Allows you to select text objects containing a particular key word or phrase.
To take into account the case of the key phrase (uppercase/lowercase as entered in the text field), select the Case sensitive checkbox.
Tip: To only select a particular key word (and not the entire text object it belongs to), you could first split the text objects, using Split in words.
