If desired, you can indicate that for objects of which stroke and fill have the same color, the width of the fill and stroke should be added together.
This Action is typically used to select and afterwards remove thin white lines that may be visible on small screens (e.g. on an iPad screen).
Select objects with width of Filled rectangle smaller than 0.0353 cm Calculate whole thickness when stroke and fill have the same color <!-- selected -->Following objects will be included in the selection:
