Belongs to
Category: Prepress
Type: Changes
Since version: 13
What it does
Allows you to add bleed all around the page, e.g. on all 4 edges if needed.
You may use this Action to make your file PDF/X-4 compliant.
How to proceed
- Select the edge(s) you want to add bleed to. Bleed is added from the trim box edges to the
bleed box.
- Indicate the amount of bleed to add. The default is 1 mmm.
Note: By default, the same amount
of bleed is added on all edges; if you change one value, all other values are automatically
changed as well. If you don't want this, click the Lock icon
, so it changes to
. You can now use different values as
required.
- Select Mirror margins according to page binding as required. When
selected, the inner and outer instead of the left and right margins have to be set, so the
amount of bleed may be different for even and odd pages.
- Select Add bleed in corners as required.
Pre-defined Action Lists
PitStop 13 comes with two new standard Action Lists allowing you to add bleed to your PDF:
- Generate Bleed to 3mm if none, and correctly set all Page Boxes
- Generate Bleed to 3 mm if some, none, or not enough.
You can use these Action Lists as they are, or modify them to meet your requirements. For
more information, open the Action Lists in the Action Lists dialog (under "Standard") and read
the description.
Related Actions
This Action applies bleed based on the bleed box; if you don't have a bleed box yet, you can use the Action below to create it.
