Check Esko barcode value
Belongs to
What it does
Checks if the Esko barcode contains or equals a particular string. You can take into account the case of the string or use regular expressions or Smart Preflight variables as required. The actual value of the Esko barcode is mentioned in the log, in the Navigator and in the Preflight Report, for example: Esko barcode value "1234567890128" does not contain "222".
Both the new ArtPro Plus barcodes as well as the old XMP ones are supported.
Note: The metadata attached to the barcode is checked. If the metadata is absent, the Action won't be able to check the barcode.
Related Actions
Select Esko barcode
