| Graphics |
Select the clipboard that contains the objects to be pasted. Determine whether or
not the clipboard should be cleared after the object was pasted. This option determines
what happens if there are no objects to be copied (= if the select Action in step 2 of the
above procedure results in an empty selection).
- If checked, the clipboard will be empty, so nothing will be pasted.
- If cleared, the clipboard will still contain content from the previous page and that
content will be pasted.
| Attributes |
Determine if the objects should be pasted in the foreground or in the background of the
document.
| Region |
Determine the region where the objects should be moved to. The region is defined
based on the page box of your choice and you can define margins within that page box, by
grabbing the offsets from a selected area (using the Grab position
button ). You can also
specify a specific area the objects should not be placed in, also based on a page box and
with the option to set margins.
Note: The settings on this tab are only used if
Move graphic elements is selected on the Position tab. If this is
not the case, the original location of the graphic elements is preserved.
| Repeat |
If the objects should be pasted more than once on a page, change No
repeat to:
- Distribute/Repeat fixed number of graphic elements if you want
to determine how often the copied objects should be pasted (e.g. 6 times horizontally, 4
times vertically)
Distribute/Repeat graphic elements in region if you want PitStop
to fill the region (specified on the Region tab).
If you want PitStop to divide the pasted objects evenly across the defined
region, choose "distribute" rather than "repeat". In case of "Distribute graphic elements
in region", you can choose the maximum or minimum distance between the pasted objects.
If you choose "repeat", you should define the exact distance between the pasted objects
yourself.
The distance can be between the bounding boxes of the pasted objects
(choose: Between edges) or from center to center (choose:
Between centers).
Note: Remember that you can use Smart Preflight variables to define the distances.
| Position |
If the selected objects should be moved, select Move graphic
elements. Indicate how the objects should be positioned relative to the chosen
region. Note that, when adding multiple copies, the same corner should be used to position
the graphic elements in the region. |
