Allows you to change the order of the pages in a document.
When you select one of these options, you can immediately see the new page order in the Preview section at the bottom of the pane.
Apart from that, you can configure for each individual page what the new page number should be. To do so, you should select 'Custom' from the list of options and enter the page numbers in the preferred order (one by one, or using the notation explained in the GUI).
| Notation | Meaning |
| One single page number 5 |
Put this page first, then add the other pages without changing the order.
5, 1, 2, 3, 4, 6, 7, 8, 9, 10 |
| R followed by one page number R5 |
Put this page counting from the back first, then add the other pages without changing
the page order. 6, 1, 2, 3, 4, 5, 7, 8, 9, 10 |
| One single page number followed by three dots 5... |
Put this page first, add the following pages till the end of the document, finally
add the missing pages (all without changing the page order). 5, 6, 7, 8, 9, 10, 1, 2, 3, 4 |
| R number followed by three dots R5... R1... |
Put this page counting from the back first, then put the following pages counting
from the back of the document, finally add the other pages (7-10) 6, 5, 4, 3, 2, 1, 7, 8, 9, 10 10, 9, 8, 7, 6, 5, 4, 3, 2, 1 |
| (number, number) ... (2,1)... (6,5)... |
Swap the pages in between the brackets and do the same for the rest of the document.
Other pages are added at the end. 2, 1, 4, 3, 6, 5, 8, 7, 10, 9 6, 5, 8, 7, 10, 9, 1, 2, 3, 4 |
R number (number-number) number (number, number) R1 (3-6) 2 (8,7) |
Put the last page first (10), then a page range (pages 3 to 6), then a particular page (2), then swap even and odd pages (swap 8 and 7), add leftover pages (1, 9). 10, 3, 4, 5, 6, 2, 8, 7, 1, 9 |
