Belongs to
Category: Position and Size
Type: Selections
- Since version: 13 update 1
What it does
Selects objects using the area defined by the current selection. This Action is useful to
select objects only within a defined shape, such as a Dieline or a Cutter Guide.
There are several options. You can select:
- The objects inside or outside the contour.
- The objects inside or outside the contour or overlapping contour.
- The objects completely covering the area inside the contour.
Note that this Action must be preceded by a Select Action in the same Action List (for example
a Select spot color or a Select objects on layer Action). You can use any "select" Action you
want, e.g. select by layer, by color, by line weight and you can use even operators (AND, OR) as
required, but remember that only the basic shape of the selected line art objects will
contribute to the contour!
Remarks
- Clipping is taken into account when determining whether an object lies inside or
outside the contour. For example, if an image is partly outside the contour, but this part is
clipped, it's considered to be completely inside the contour.
- In case of complex shapes, the even-odd rule is used to determine what lies inside the
contour. This rule supposes that you draw a line between a point inside the shape outline and a
point outside its outline.
- If that line crosses the line of the shape an odd number of times, the shape area to which
the point belongs, is filled.
- If the number of crossings is even, the area is not filled.
On the image below, the contour area (marked in red) is determined by applying the
even-odd rule to the two selected line art objects (two ellipses, one inside the other).
- The line art that is used to determine the contour area (through the preceding "select"
Action) is not selected by "Select inside contour"; only the objects (images, shadings - which
may have exactly the same shape as selected the line art) in that area will be part of the
selection. This is illustrated in example 2 and 3.
- New in 13 update 2: you can even select objects inside or outside a non-closed contour or
one with gaps using the Ignore gaps in contour if smaller than ...
checkbox.
Example 1
This Action List logs all images inside the contour formed by all line art on the Cutting
layer:
Select by layer "Cutting"
Select images
Select AND
Log selection
Example 2
This Action List moves all elements belonging to the barcode to a separate layer. Note that
the technical contour around the barcode is not moved!
Select spot color "Barcode area"
Move to layer "Barcode"
Example 3
This Action List converts the color of all objects with spot color "Content area" to CMYK. The
"content area" spot color itself is (obviously) not touched.
Select spot color "Content area"
Convert selection to CMYK
