Belongs to
Category: Add
Type: Changes
Since version: 2018
What it does
Adds the barcode of your choice. You can select the barcode you need from a list of common
barcode types, choose the color of the back- and foreground and specify the position.
Tabs
| Tabs |
| Barcode |
| Color |
- Choose the foreground color. The default color is black.
- Select a background as required and pick a background color.
| Position |
- There are two options to specify the position and size of the barcode:
- Use selection bounding box: if selected, the barcode will be placed on the
bounding box of an object in the PDF that is selected. The size of the selected object
determines how big the barcode will be.
- Specify position and size: Size and position can be defined independently
from each other.
The absolute position is set by entering the X and Y
coordinates.
The relative position is determined by the distance and position
relative to one of the page boxes.
The size is set by entering the width and
the height. If the lock icon looks closed, any changes you make to one of the
dimensions changes the other dimension proportionally.
- You can use the default quiet zone or you can determine the dimensions. The
lock icon can be used to make sure proportions are kept if changes are made
afterwards.
- Barcodes can be rotated as required. Rotation angles are 90°, 270° and
360°.
Note: This Action supports variables in most fields.
Standard Action Lists
PitStop 2018 comes with a number of default Action Lists for generating barcodes.
Some of these Action Lists make use of smart variables; to that end a new Variable Set was
added to PitStop 2018 (Smart Preflight Variable Set - PitStop Pro v1.3).
If you're not familiar with Smart Preflight, we recommend taking a short elearning course on
Smart Preflight, available on the Enfocus website (https://www.enfocus.com/learn), or check out the
PitStop Reference Guide, which has a chapter on Smart Preflight too.
