Close gaps in contour
Belongs to
What it does
Allows you to close gaps in contours. You can set the threshold, e.g. only close gaps that are smaller than 0,10 cm.
If gaps should only be closed if the result is a closed contour, select the corresponding checkbox.
Remark
We recommend using this Action in combination with Override rounding rules because of precision issues.
Related Action
