Allows you to combine the selected objects into one shape or vice versa, divide a shape in multiple parts.
If you want to keep the original shapes, select Create copy. The changes will be made on the copy and the original shapes will be kept as they are.
Combine/Divide Shapes is also an option in the PitStop Pro > Object menu and in the context menu when you make a selection, and a tab in the PitStop Inspector.
Select line art Combine and divide shapes <!-- Choose an option -->
| Chosen option | Result |
| Unite | ![]() Note that the new shape gets the color of the front/top shape. |
| Intersect | As there is no part where all three objects are stacked on each other, the intersection is empty and all shapes are removed. |
| Exclude | ![]() |
| Minus front | ![]() |
| Minus back | ![]() |
| Divide | ![]() Once divided, you can for example move the different parts apart.
