Belongs to
Category: Color
Type: Selections
Since Version: 2018
What it does
Selects black and white images.
You can set a tolerance (an allowed deviation from '100% gray', default tolerance is '3') and
tell PitStop how to determine what black and white is:
- Calculate image average: Take the color value of each pixel of the
image (color and gray values) and calculate the average of this; decide based on this value
whether or not it is "black and white".
- Look for colored areas: Search for colored areas and take only the
values of colored pixels to decide whether or not it is "black and white". If most of the
colored values are gray (or close to gray/taking into account the chosen tolerance), the image
will be considered black and white; otherwise it will be considered a color image. This method
will detect images that are mainly black and white but with a small colored area.
Remarks
- This Action works on all color spaces, on images, text and linear and radial shadings.
- Spot colors are always considered colored images, regardless of their name (e.g. even spot
colors with the name 'black' will be considered colors).
Examples
The following image will be considered 'black and white' based on the average image
calculation, but 'colored' based on the area calculation.
The image below is clearly 'black and white' and will be selected, regardless of the
calculation method.
