Belongs to
Category: Position and Size
Type: Selections
- Since Version: 2017
What it does
Selects objects based on their relationship with other objects they interact with, i.e.
objects that (at least partly) lay on top of, or below other objects.
There are four options:
- The first option allows you to select objects that (at least partly) overlap any
object on the page.
- The second option allows you to select object that (at least partly) are overlapped
by any other object on the page
- The third option allows you to select objects that (at least partly) are on top of other
objects selected earlier in the same Action List.
- The third option allows you to select objects that (at least partly) are below other
This Action is included in a number of default Action Lists:
Example
The following Action List will remove all objects that are on top of the text in your
PDF:
Select text
Select overlapping objects (third option selected)
Remove selection
