This is an example of how you can fix problems reported by the Enfocus Navigator.
Problem: You have run an Action List which includes the Check resolution Action. You get an error saying that the resolution of some images in your PDF document is too high.
Solution: Check and resample the images as required.
To simulate this use case, proceed as follows
preceding the warning "Resolution of color or grayscale image is more than x
ppi (3x on pages y-z)"
