This topic describes how to run an Action List. The procedure is identical, regardless of whether you have created the Action List yourself, or if you're using a standard Action List provided by PitStop Pro or an imported Action List.
To run an Action List
The Enfocus Navigator is a dialog that gives an overview of the changes performed by the selected Action List and enables you to generate a (Preflight) Report. This Preflight Report is a PDF document that displays general file information as well. See Checking the results of an Action List.
Select the appropriate option:Errors can only be detected for Actions of the type "Check", if you have selected Log as error or Log as error and allow Sign-off (in the attributes of the "check" Action).
If you have chosen an "inform" Action, the requested information will be included in the Report, so make sure to select Always.
