Creating your first flow
Working with flows always requires the following steps:
  1. Create a new flow for the process you want to automate. You can start from a blank flow (and design it from scratch) or start from a sample flow.
  2. Design your flow, by dragging the required flow elements onto the canvas. You must configure the properties of all flow elements and connections on the canvas.
  3. Run your flow: i.e. save, activate and test the flow using test files, until you are happy with the result.
