In Switch 13 update 1 the Switch apps were introduced: small applications that can be used as flow elements in Switch, just like the Configurators, but without the need of a license for the Configurator Module.
These apps are developed by Enfocus or 3rd party providers and can be purchased through the Enfocus Appstore.
The purchased apps can be found in the Flow elements pane in a separate category, under "Apps",
as shown below.
Once purchased and installed, apps are used just like other flow elements.
Note that you will receive notifications in Switch to inform you about your apps, for example if a new version is available or if your subscription is about to expire. More information can be found in the Switch Reference Guide, available on the Enfocus website.
