Saving a flow
In the Flows pane, unsaved flows are displayed in italics, followed by an asterisk.
To save a flow
  1. In the Flows pane, select the flow you want to save. Optionally, you can select several flows, to save them all in one go.
  2. Do one of the following:
    • In the toolbar at the top of the screen, click .
    • In the Flows pane, right-click and select Save Flow(s).
    • From the menu, select Flow > Save Flow(s) .
    In the Flows pane, the flow name is no longer displayed in italics and the asterisk has disappeared.
    Note: As soon as you start making changes to the saved flow, the name is again displayed in italics, followed by an asterisk. Note that you can always go back to the last saved version, by clicking the Revert Flow button in the toolbar.
