Open a PDF2Go document.
In the Adobe Acrobat x, navigate to and click this
button to display the Enfocus Inspector.
In older versions of Adobe Acrobat, choose or click the Show Inspector
button
to
Click the Select Objects tool
The
cursor changes into an eyedropper.
Click on a random position in
the PDF document:
- If you clicked on the LW layer, the Enfocus Inspector dialog box will display both the source
and target color.
Figure 1. Enfocus Inspector when clicked on the LW layer:
source color (A) and target
color (B) are displayed.
- If you clicked on the CT layer, the Enfocus Inspector dialog box will display only the color
of the current selection, meaning that you can only make color retouches
in the LW layer of PDF2Go documents.
Click on the color you want
to change in the line-work (LW) layer.
The
selected (source) color will appear in the Selection area
in the Enfocus Inspector.
Hold down the ALT key (Windows)
or Option key
(Macintosh) and click on a target color, i.e. a color into which
you want to change the selected color.
You
can click on a color of a CT or a LW layer. The selected target
color appears in the Replace
with area of Enfocus Inspector.
If necessary, change the target
color by moving the sliders.
Select an Overprint setting.
Do one of the following:
- To replace the source color with the target color
in the entire document, click Replace in Document.
color on the current page only, click Replace on Page.
color in a specific area, zoom in on the area, and draw the area
using the Select
Rectangular Area
or Select Polygonal Area
tool. Then click Replace in Area.
