Using the Color Management Preset Editor
  1. Define the name and Description
  2. If you want to use the active settings in your preset, select Grab current Color Management Preferences from the Actions menu. All these settings will be entered automatically.
  3. If you want to use the Acrobat Preferences in your preset, select Grab current Acrobat Preferences from the Actions menu.
  4. Configure the general color management settings in the General tab.
  5. In the Images tab, you can select the Apply General color settings checkbox to apply the general settings for the images too or you can select the Enable color management checkbox to override the general color settings and configure separate settings for images.
  6. Select a default source and target ICC profile for each color space. By selecting Sync with Acrobat, the corresponding ICC profile defined in the Acrobat preference will be used.
  7. Select the CMM Engine to be used, and (if applicable) select Use black point compensation checkbox.
  8. Click the Save button to just save the settings or click the Save and Apply button to apply the settings too.
