You
may want to use the Select
Similar Objects tool
to select all the text or line-art
objects on the page which have the same color.
The Enfocus Inspector displays the current color settings of the selected objects.
If necessary, you can now specify the fill and/or stroke attributes of the selected objects.
Cap style |
Join style |
Icon |
Meaning |
Icon |
Meaning |
Butt cap |
Miter join |
Round cap |
Round join |
Projecting cap |
Bevel join |
With stroke adjustment, all vertical and horizontal lines can be rounded to an integer number of pixel thickness to give them the appearance of the same weight.
When several strokes with the same line weight are rendered at low resolution, their rasterization may result in lines of different widths in device pixels (with a difference of one pixel at the most). This effect depends on how the exact position in real numbers of these strokes intersects with the device pixel grid. For a better visual result, automatic stroke adjustment can be enabled. This will counteract the rasterization effects, by slightly changing the line weight and coordinates, thus producing lines of uniform thickness in device pixels.
