If the QuickRun you want to run is part of the Favorites database,
you can click the button of your choice on the QuickRuns toolbar, or use the
assigned shortcut.
Otherwise, you can open the QuickRun panel, select the
QuickRun you want to run, and click the Run button.
When the Quickrun has finished, a report or the Enfocus Navigator may appear,
depending on your Enfocus PitStop Pro
Preferences.
