To find and replace text:
In the Adobe Acrobat X, navigate to and click the Enfocus Find And Replace
Text option to open the panel. Or navigate to and click this
button to open the
Enfocus Find And Replace Text dialog box.
In older versions of Adobe Acrobat, navigate to and click the Enfocus Find And Replace
Text to open the panel. Or navigate to .
In the Find And Replace Text dialog box, type the text
you want to search in the Find textbox.
Select the Case sensitive checkbox if you want to find
the exact word that you type (i.e., upper case or lower case).
Select the Current page only checkbox to restrict your
search to the current page of focus only.
Choose the Select partial text objects checkbox if your
search query is only a part of a whole word.
Click the Next button to perform the search, the first
instance of the search term will be highlighted when found. Continue to click
the Next button to find all instances of the search term
till the end of the document. When the search has been performed till the end of
the document, a message box appears displaying the message Text search
has reached the end of the document. Click OK
button in this message box and click the Next button to
continue the search from the beginning of the document.
Alternatively, you can click the Previous button to
search from anywhere in the document to the beginning of it.
If you want to replace the search term with another word of your choice, type
the word in the Replace textbox. Click the
Replace button to replace a search term which has
already been highlighted or click the Find & Replace
button to replace the currently highlighted search term and find the next
instance of it.
