To run a preflight check
  1. Open the Enfocus Processing - Preflight panel by clicking the Enfocus Processing - Preflight button
  2. Select a Preflight Profile in the Preset Manager
  3. Set the page range on which you want to perform the Preflight check
  4. If you want the Preflight to be a part of the Certified PDF workflow, select the Certified PDF Preflight checkbox. See also Difference between a Certified and a regular preflight check
    If the document is not yet in a Certified PDF workflow, choosing this option and running the preflight will start the Certified PDF Workflow. See Working with Certified PDF documents
    Note:
    A Certified PDF Preflight is always run on the complete document. When choosing Certified PDF Preflight, the page selecting options will be unavailable.
  5. Define if you want to Allow fixes. If the Preflight Profile doesn't allow fixes, the option will be disabled.
  6. Click the Run button
Enfocus PitStop Pro will run the Preflight on the selected pages, using the selected Preflight Profile.
After finishing, the Enfocus Navigator will show all errors, allow to restart the Preflight, suggest solutions, etc. See Using the Enfocus Navigator
