In the SETUP section, click the
General label and define the name and
description.
Click the + button to add the New
variable label to the VARIABLES
section.
Click the New variable label to view the fields related
to it in the right pane.
Enter the Name and the User Readable
Name in the Variable Definition
section.
Select Inline value (the default) for the
Type drop-down menu to enter an explicit
value in the Value text field of the
Variable Value section. Select
Number, Length,
String or Boolean for
the value.
Select Rule Based for the
Type drop-down menu. The Variable
Value section displays the property editor which allows
defining a condition that combines multiple comparisons, using IF-ELSE
statements. Each comparison is represented as a separate row.
To add a comparison row: Select the variable in the first drop-down
menu and select the condition in the second drop-down menu. Enter the
value in the textbox and click the AND or the
OR button to add the desired logical
operator. A new comparison row is added.
To remove a comparison row: Click the Remove
button present at the end of that row.
Press the Shift key to view additional
options.
Click the Copy button to copy the existing
statement and reuse. Click the Delete button to
delete a statement.
Click the ELSE button to append a new set of
comparison rows.
You can also configure for a scenario when none of the conditions
previously set match: Select the Generate a
failure radio button or select the Use this
value radio button and choose On
or Off in the drop-down menu.
Click the Save button to save these settings.
See Smart
Preflight for more information on configuring Variable Sets and smart
preflighting.
