About undoing and redoing actions
You can undo any unsaved actions which you have done with one of the PitStop Pro tools. An “action” can mean changing something but also selecting one or more objects.
To undo your actions, you have two buttons in the PitStop Pro panel (Acrobat X and XI) or in the Enfocus Undo & Redo toolbar (Acrobat 8 and 9):
Button Undoes Usage
Changes only.
In situations where you have done multiple changes and maybe made some selections in between.
For example: select text, move it on the page, change the font and color. Select an image, scale it and place it below the text.
Changes and selections.
In situations where you have made a lot of selections, and some­times even very complex ones, for example using the Enfocus wire­frame view (  ). Or when you were selecting a lot of objects and you lost your selection due to a “slip of the mouse”.
After undoing one or more actions, you can redo them again, using Redo and Redo Selection.
Note: If you are working with Certified PDF documents, you can even undo actions after you have saved the file.
