Suppose you have PDF documents of booklets that are almost
press-ready. The pages are to be printed double-sided, folded and trimmed. You want to
make sure that the page numbers, which are close to the edge of the page, do not get
trimmed off. Indeed, when pages are folded for saddle-stitch binding, the printed area
slightly moves outward. This is known as creep in the
publishing world. The more pages in a booklet, the larger the shift of the area of the
inner pages will be.
Figure 1. Creep moves the printed area of the inner pages outwards,
which may cause page numbers near the outer edges of the pages to be trimmed
off.
To compensate for this creep, you can create an Action List that does
the following:
- Shift the printed area of the left-hand (even-numbered) pages
5 mm to the right.
- Shift the printed area of the right-hand (odd-numbered) pages
5 mm to the left (closer to the binding).
- Leave the first page unchanged (for example because this page is
not numbered).
Figure 2. Changing the page layout: move the printed area of the
inner pages (B and C) towards the binding to compensate for creep, but leave the first page
(A) unchanged.
