Regular preflight
A regular preflight does not change the Certified PDF status of the PDF document:
If, at the time of preflighting,
Then
The PDF document is not a Certified PDF
The PDF document will remain "unCertified".
The PDF document is a Certified PDF
The Preflight Profile embedded in the Certified PDF document will not be removed, even if you preflight the PDF document with a different Preflight Profile in the Enfocus Processing Panel.
