A Certified PDF preflight checks and changes the Certified PDF status of the PDF document as follows:
If, at the time of preflighting, |
Then |
The PDF document is not a Certified PDF |
You will be asked whether you want to start a Certified PDF workflow for this PDF document. |
The PDF document is a Certified PDF |
The PDF document will already have a Preflight Profile embedded. PitStop Pro will check whether the Preflight Profile you selected in the Enfocus Processing Panel is the same as the embedded Preflight Profile: If the Preflight Profiles match, the PDF document will be preflighted. If the Preflight Profiles do not match, you will be asked whether you want use the Preflight Profile you just selected in the Enfocus Processing Panel instead of the embedded Certified Preflight Profile. |
