Text or text segments?
There are several PitStop Pro tools which you can use to select text or a text segment in your PDF document. A text segment can be:
Figure 1. Text segments: a line (A), a word (B) and single characters (C).
The way in which you select the text or a text segment often depends on what you want to do with the selected text. You will typically:
You may want:
