If you need to make comprehensive changes to text which spans across
multiple lines, you can use the Edit
Paragraph tool
You can use this tool to select a “logical text entity”. A logical text entity is generally a
chunk of text between two punctuation marks or spaces, or with different font properties. You
can also use it to add a new paragraph of text to your PDF document.
